F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-05-2002, 05:00 PM
Vehicle: 1998 Ford F-150
Shudder in the transmission
I have a '98 150 Ford 4X4 Off Road with a 4.6 and automatic trans. I currently have 90,000 miles on this vehicle. I tow a livestock trailer about 30% of the time. Problem: I recently noticed that the truck will shudder (like the truck is running over rumble strips in the road) for only a second or so whenever the transmission shifts into high gear. This happens from 35 - 55 MPH. This will happen whether OD is on or off and is more noticeable when I tow.
Any thoughts?
Old 12-05-2002, 05:22 PM
Vehicle: 1997 Ford F150
Fluid Change
I think if you search this forum you'll find that in most cases the fluid is worn out and needs to be changed. How long has it been since you've done yours? 30K should be the max.
John
97 SC XLT 4.6L, 3.55 L/S, Tow Pkg,
K&N Gen II FIPK, 75MM BBK TB,
Gibson Super Truck Exhaust,
Superchips Microtuner 1715,
Accel Coils,PA Valve Body,
Hawk HPS Pads, Rancho RSX Shocks
Steel Horse Billet Grille's
Old 12-05-2002, 05:59 PM
Re: Fluid Change
Quote:
John
John,
I had the fluid changed almost a year ago...approximately 20K miles.
Old 12-05-2002, 07:00 PM
Growl,
Sorry, that was the obvious question. I'm really not sure. If you hang on, someone will post another idea I'm sure.
John
Old 12-05-2002, 07:02 PM
Vehicle: 2005 Ford F150
sounds like the infamous torque converter shudder...the cheapest way to fix this is prolly to have the tranny fluid changed again and make sure they put mercon V in it...
mercon V was specified to help with torque converter shudder on the 4r70w which is the tranny you have...
Old 12-05-2002, 11:09 PM
Easy to fix...LUBEGUARD
I had the same problem that drove me nuts. Had the trans and TC flushed and fluid changed and that held out for a couple months...then the shudder came back. I talked to a guy who restored older cars, and he told me to just put in an additive. I tried "LubeGuard" (I'm pretty sure that's the name)...and it worked And the best thing is...it's still working. I have no more tranny shudder at all. There are a few different additives, this one came in a red bottle (hopefully they don't all come in red bottles). It says on the bottle that it helps stop transmission shudder...they're right.
Try it...cheap fix for under $10
Scott
'97 F150 4.6L 4x4 ORP
K&N FIPK Gen II
Hellwig Rear Antisway Bar
Front Steering Stabilizer
BFG All Terrain T/A ko
A.R.E Cap
OEM Door Cracks (both doors-ooh, lucky me!!)
Infamous "Tranny Shudder" -a.k.a.- factory installed intermittant vibrating seat (now seemingly fixed with "LubeGuard")
SuperChip "Flip-Chip" (Thanks Mike T. and company!)
MSD Coil Packs w/ Ford Racing wires (not that they make me go any faster)
Nakamichi MB-75 Indash 6 CD Changer (now with broken changer...stuck with AM/FM)
Nakamichi PA-1004 Amplifier, 50 watts x 4
Infinity Kappa 5x7s
Electric Fans (Thanks again Troyer Performance)
New Jasper Reman. 4.6L engine (thanks to bad head gasket and sudden engine failure)
Now I'm broke...no more mods for a while
Old 12-06-2002, 10:58 PM
Vehicle: 1997 FORD F-150
Had the same problem! Some of these replies might work. I did try them but with the luck I have none work. I dropped my trans pan and took a look. Needless to say, when I ran my finger on the bottom, It came out looking like pudding! 1500 to rebuild, 2200 for a new one. But Jeg's set me up with a TCI Heavy-Duty for $867 Shipped! (less bellhousing). Hope these replies work for you! My luck just hasen't been good lately! Thanks to all that help me out!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
