Quote:
<font face="Verdana, Arial" size="2">My 99SC...line out from AT goes to top fitting on side of rad. Return line goes from bottom rad. to external cooler back to AT.</font>
So does mine.
Quote:
<font face="Verdana, Arial" size="2">You installed manifold in OUT hardline..</font>
Yes.
Quote:
<font face="Verdana, Arial" size="2">OUT line gave irratic reading, said put in RETURN line.</font>
They probably screwed something up. My readings are EXTREMELY stable.
Quote:
<font face="Verdana, Arial" size="2">You said temps went up climbing long slow grade. Are you still convinced this is the best place (outline) to install manifold.</font>
I could measure the fluid coming from the cooler or the bulk fluid temps in the pan and feel good about how cool my trans is running .... but I'd only be kidding myself. I want to know the MAXIMUM temp that my trans is reaching. Others are entitled to their own opinions. If my maximum temp stays under 220F (I'm using Amsoil ATF stable to 260F) then I'm happy.
Good luck ...
'00 5.4L AUTO 4X4 F-150 Lariat
'98 4.0L 5spd Jeep Wrangler Sport
'95 3.8L SC Thunderbird
'02 F-350 PSD CC DRW 6SPD 4X4 Lariat (order this year)
www.hawthorn-engineering.com
