Technical Service Bulletins For The 1998 F150
Service Bulletin Number: 99128
Bulletin Sequence Number: 645
Date of Bulletin: 9906
NHTSA Item Number: SB606449
Make: FORD TRUCK
Model: F150
Year: 1998
Component: AIR CONDITIONER
Summary: SOME VEHICLES MAY EXHIBIT A WHISTLING NOISE WHILE DRIVING WITH A/C IN THE OFF SOME VEHICLES MAY EXHIBIT A WHISTLING NOISE WHILE DRIVING WITH A/C IN THE OFF POSITION AT SPEEDS ABOVE 64 KM/H (40 MPH). *TT POSITION AT SPEEDS ABOVE 64 KM/H (40 MPH). *TT
Service Bulletin Number: 99196
Bulletin Sequence Number: 609
Date of Bulletin: 9909
NHTSA Item Number: SB6090087
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INFORMATION ON IDENTIFYING NON-APPROVED / ALTERNATE REFRIGERANTS WHICH COULD CAUSE SAFETY, AND PERFORMANCE CONCERNS IF INSTALLED IN FORD A/C SYSTEMS. *TT
Service Bulletin Number: 99144
Bulletin Sequence Number: 841
Date of Bulletin: 9907
NHTSA Item Number: SB608420
Make: FORD TRUCK
Model: F150
Year: 1998
Component: AIR CONDITIONER:COMPRESSOR
Summary: VEHICLES MAY EXPERIENCE A MOANING NOISE HEARD AT APPROXIMATELY 1100 RPM WITH THE A/C COMPRESSOR ENGAGED. *TT
Service Bulletin Number: 99107
Bulletin Sequence Number: 648
NHTSA Item Number: SB606481A
Make: FORD TRUCK
Model: F150
Year: 1998
Component: BRAKES:HYDRAULIC SYSTEM
Summary: A GRABBING CONDITION FROM THE REAR BRAKES DURING THE FIRST FEW BRAKE APPLICATIONS AFTER EXTENDED HUMIDITY EXPOSURE MAY OCCUR ON SOME VEHICLES. *TT
Service Bulletin Number: 99194
NHTSA Item Number: SB6090082
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INFORMATION FOR SERVICING AND DIAGNOSING BRAKE VIBRATION, BRAKE INSPECTION, AND BRAKE FRICTION MATERIAL REPLACEMENT. *TT
Service Bulletin Number: 991313
Bulletin Sequence Number: 651
NHTSA Item Number: SB606515
Make: FORD TRUCK
Model: F150
Year: 1998
Component: BRAKES:HYDRAULIC:ANTI-SKID SYSTEM
Summary: SUBJECT REGARDING ANTI-LOCK BRAKE LAMP ILLUMINATION, INCREASED BREAK PEDAL EFFORT AND / OR FALSE ANTI-LOCK BRAKE SYSTEM (ABS) CYCLING AT LOW SPEEDS. *TT
Service Bulletin Number: 985A5
Bulletin Sequence Number: 102
Date of Bulletin: 9803
NHTSA Item Number: SB601003
Make: FORD TRUCK
Model: F150
Year: 1998
ISC:ROTOR
ISC HUB
Summary: HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT FROM ROTUNDA IS NOW APPROVED FOR WARRANTY AND SERVICE USE. *YC
Service Bulletin Number: 9814
Bulletin Sequence Number: 556
Date of Bulletin: 9801
NHTSA Item Number: SB605562
Make: FORD TRUCK
Model: F150
Year: 1998
ISC:ROTOR
ISC HUB
Summary: SUBJECT REGARDING THE AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT. *TT
Service Bulletin Number: 99411
Bulletin Sequence Number: 478
Date of Bulletin: 9903
NHTSA Item Number: SB604767
Make: FORD TRUCK
Model: F150
Year: 1998
Component: BRAKES:HYDRAULIC:OTHER
Summary: VEHICLES EXPERIENCING INCREASED BRAKE PEDAL EFFORT AND / OR FALSE ABS CYCLING AT LOW SPEEDS, OR ABS LAMP ILLUMINATION. *TT
NHTSA Item Number: SB606482
Make: FORD TRUCK
Model: F150
Year: 1998
Component: BRAKES:HYDRAULIC:SHOE AND DRUM SYSTEM
Summary: CONDITIONS ON REAR DRUM GRABBING DURING FIRST FEW BRAKE APPLICATIONS WHILE BRAKES ARE COLD. *TT
Service Bulletin Number: 9845
Bulletin Sequence Number: 128
NHTSA Item Number: SB601264
Make: FORD TRUCK
Model: F150
Year: 1998
Component: BRAKES:ROTOR
Summary: AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT. *YC
Service Bulletin Number: 98246
Bulletin Sequence Number: 408
Date of Bulletin: 9812
NHTSA Item Number: SB604059
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ELECTRICAL SYSTEM
Summary: FORD MOTOR COMPANY HAS RELEASED A NEW ELECTRICAL GREASE ( F8AZ - 19G208-AA ) TO REDUCE THE POSSIBILITY OF MOISTURE CORROSION AT THE TERMINALS. *YC
Service Bulletin Number: 4660
Bulletin Sequence Number: 151
Date of Bulletin: 9808
NHTSA Item Number: SB615196
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ELECTRICAL SYSTEM:BATTERY:OTHER PART
Summary: SUBJECT REGARDING THE NAGATIVE BATTERY TERMINAL COVER ON SOME VEHICLES. *TT
Service Bulletin Number: 99164
Bulletin Sequence Number: 765
Date of Bulletin: 9908
NHTSA Item Number: SB607657
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ELECTRICAL SYSTEM:IGNITION:OTHER PART
Summary: CONCERNS WITH A HARD TO TURN IGNITION KEY AND / OR A HARD TO REMOVE KEY FROM IGNITION CYLINDER. *TT
Service Bulletin Number: 99222
Bulletin Sequence Number: 608
Date of Bulletin: 9910
NHTSA Item Number: SB6089681
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ELECTRICAL SYSTEM:WIRING
Summary: SUBJECT ON A WIRE HARNESS TERMINAL REPAIR KIT AVAILABLE FOR REPAIRING ELECTRICAL WIRING HARNESSES. *TT
Service Bulletin Number: 982117
Bulletin Sequence Number: 370
Date of Bulletin: 9811
NHTSA Item Number: SB603680
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EMERGENCY PARKING BRAKE:OTHER PART
Summary: A NEW PARKING BRAKE CONTROL RUBBER BUMPER STOP IS NOW AVAILABLE FOR SERVICE. *YC
Service Bulletin Number: 980317
Bulletin Sequence Number: 353
Date of Bulletin: 9804
NHTSA Item Number: SB603510
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: SYMPTOMS REGARDING P0300-P0308 MISFIRE DTCS WITH 4.6L ENGINES. *YC
Service Bulletin Number: 982110
Bulletin Sequence Number: 369
NHTSA Item Number: SB603673
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: DURING HIGH IDLE SPEEDS THROTTLE STICKS AFTER STEADY STATE DRIVING IN COLD AMBIENT TEMPERATURES. *YC
Service Bulletin Number: 99816
Bulletin Sequence Number: 642
Date of Bulletin: 9905
NHTSA Item Number: SB606420
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: FORD MOTOR COMPANY NOW RECOMMENDS SAE 5W-30 VISCOSITY GRADE FOR SERVICING ANY FORD GASOLINE-POWERED VEHICLE REGARDLESS OF MODEL YEAR. *TT
Service Bulletin Number: 996034
Bulletin Sequence Number: 694
NHTSA Item Number: SB606947
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: EXPERIENCING A ENGINE KNOCK AT COLD START-UP. *TT EXPERIENCING A ENGINE KNOCK AT COLD START-UP. *TT
Service Bulletin Number: 98-4738
Bulletin Sequence Number: 714
Date of Bulletin: 9809
NHTSA Item Number: SB607152
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: COLD ENGINE KNOCK 5.4L ACTION. *AK
Service Bulletin Number: 983316
Bulletin Sequence Number: 747
Date of Bulletin: 9802
NHTSA Item Number: SB607481
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: SOME CUSTOMER MAY COMPLAIN OF A TICKING NOISE ON INITIAL COLD START-UP IN PARK POSITION AND NEUTRAL POSITION. *TT
Service Bulletin Number: 99188
NHTSA Item Number: SB6090068
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: VEHICLES WITH 4.2L ENGINE (CANADIAN) MAY BACKFIRE ON ACCELERATION AT ALL AMBIENT TEMPERATURE. *TT
Service Bulletin Number: 8163
Bulletin Sequence Number: 123
Date of Bulletin: 0002
NHTSA Item Number: SB612337
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: SOME VEHICLES WITH 4.6L, OR 6.8L ENGINES MAY EXHIBIT A ROLLER FINGER FOLLOWER COMING OFF DURING ENGINE CRANKING IN COLD TEMPERATURES BELOW ZERO DEGREES F. A ONE-TIME NOISE FROM THE ENGINE MAY BE HEARD, FOLLOWED BY ROUGH RUNNING / MISSES, NO START, LACKS POWER AND A CHECK ENGINE LIGHT (MISFIRE DIAGNOSTIC TROUBLE CODES). *TT
Service Bulletin Number: 985185
Bulletin Sequence Number: 132
NHTSA Item Number: SB613316
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: COLD START ENGINE NOISE
Service Bulletin Number: 14039
Bulletin Sequence Number: 137
Date of Bulletin: 0004
NHTSA Item Number: SB613723
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: INFORMATION REGARDING MALFUNCTION INDICATOR LAMP ON -P030X DTC'S CONTACT REQUEST / DETROIT AREA. **MR
Service Bulletin Number: 00123
Bulletin Sequence Number: 138
Date of Bulletin: 0006
NHTSA Item Number: SB613859
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: SOME VEHICLES MAY EXPERIENCE SPARK KNOCK DURING LIGHT-TO-MODERATE ACCELERATIONS. *TT
Service Bulletin Number: 4638
NHTSA Item Number: SB615176
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: BRIEF INFORMATION ON VEHICLES EXHIBITNG A MALFUNCTION INDICATOR LAMP ON, WITH P0300 - P0308 MISFIRE DIAGNOSTIC TROUBLE CODES WITH A 4.6L ENGINE. *TT
Service Bulletin Number: 4981
Bulletin Sequence Number: 153
NHTSA Item Number: SB615321
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: SOME VEHICLES EQUIPPED WITH 5.4L ENGINES MAY EXHIBIT A COLD START ENGINE KNOCK CONCERN UNTIL WARMED UP. *TT
Service Bulletin Number: 5356
Bulletin Sequence Number: 154
NHTSA Item Number: SB615439
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
Summary: SOME VEHICLES BUILT WITH THE 4.2L ENGINE THAT ARE OPERATING IN MEXICO MAY EXHIBIT A BACKFIRE CONCERN. *TT
Service Bulletin Number: 12272
Bulletin Sequence Number: 155
NHTSA Item Number: SB615527
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE
NHTSA Item Number: SB606484
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE AND ENGINE COOLING SYSTEM
Summary: CONCERNS WITH ENGINE COOLANT LEAKING INTO ENGINE OIL ON SOME VEHICLES. *TT
Service Bulletin Number: 99207
NHTSA Item Number: SB6089651
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SUBJECT ON ENGINE COOLANT LEAKING INTO THE ENGINE OIL ON SOME VEHICLES. *TT
Service Bulletin Number: 13186
NHTSA Item Number: SB6090542
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INFORMATION REGARDING FRONT COVER & WATER PUMP BOLTS-TORQUE VALVE REVISION/3.8-4.2L. *MJS
Service Bulletin Number: 12720
NHTSA Item Number: SB6091697
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE COOLING SYSTEM:OTHER PARTS
Summary: SOME VEHICLES MAY DEVELOP A COOLANT LEAK AT THE WORM GEAR CLAMP LOCATED AT THE JOINT BETWEEN THE METAL INTAKE COOLANT TUBE AND THE FLEXIBLE RUBBER COOLANT HOSE. *TT
Service Bulletin Number: 982325
Bulletin Sequence Number: 395
NHTSA Item Number: SB603931
Make: FORD TRUCK
Model: F150
Year: 1998
Component: ENGINE:OTHER PARTS
Summary: THE MALFUCNTION INDICATOR LAMP ( MIL ) MAY ILLUMINATE AND DIAGNOSTIC TROUBLE CODE (DTC) P0455 MAY BE STORED IN MEMORY. *YC
Service Bulletin Number: 98B33
Bulletin Sequence Number: 729
NHTSA Item Number: SB607294
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: OWNER NOTIFICATION FOR REPLACEMENT OF ENGINE CYLINDER HEADS. *TT
Service Bulletin Number: 983301
Bulletin Sequence Number: 745
NHTSA Item Number: SB607462
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: THIS BULLETIN PROVIDES PROCEDURES ON NEUTRALIZING THE EXHAUST, TRANSMISSION AND ENGINE MOUNTS. *TT
Service Bulletin Number: 6996
NHTSA Item Number: SB6090309
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INFORMATION REGARDING A CHANGE IN THE TORQUE VALUES OF THE ENGINE FRONT COVER WATER PUMP BOLTS. *TT
Service Bulletin Number: 9811286
Bulletin Sequence Number: 748
NHTSA Item Number: SB607493
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EQUIPMENT
Summary: IMPORTANT INFORMATION ON USING THE NGS (NEW GENERATION STAR) TESTER ON SOME VEHCILES. *TT
Service Bulletin Number: 981517
Bulletin Sequence Number: 953
NHTSA Item Number: SB609557
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EQUIPMENT:CHILD SEAT:INFANT
Summary: INSTALL A REVISED CHILD SEAT TETHER KIT.
Service Bulletin Number: BC105849705
Date of Bulletin: 9705
NHTSA Item Number: SB052864
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EQUIPMENT:ELECTRIC EQUIPMENT:RADIO:TAPE DECK ETC.
Summary: VEHICLES WITH PREMIUM RADIOS WILL BE EQUIPPED WITH VOLUME CONTROL/ON-OFF SWITCH. *TW
Service Bulletin Number: 99129
Bulletin Sequence Number: 646
NHTSA Item Number: SB606460
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: EXPERIENCING A WHINE / BUZZ TYPE NOISE IN THE SPEAKERS OF THE ENTERTAINMENT RADIO OR TWO-WAY RADIO ON VEHICLES WITH AN IN-TANK ELECTRIC FUEL PUMP. *TT
Service Bulletin Number: 9811342
Bulletin Sequence Number: 750
NHTSA Item Number: SB607512
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INFORMATION ON REMOVING THE RADIO CHASSIS FROM SOME VEHICLES. *TT
Service Bulletin Number: 976007
Bulletin Sequence Number: 578
Date of Bulletin: 9707
NHTSA Item Number: SB605786
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EQUIPMENT:ELECTRIC POWER ACCESSORIES
Summary: BRIEF INFORMATION REGARDING CYLINDER HEAD TEMPERATURE (CHT) AND FAIL SAFE INFORMATION ON CALIBRATION CD INSTALLATION PROCESS. *TT COOLING. *TT
Service Bulletin Number: 99242
Date of Bulletin: 9911
NHTSA Item Number: SB6090184
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EQUIPMENT:ELECTRIC POWER ACCESSORIES:LOCKS
OOR
Summary: INFORMATION ON REPLACING AND / OR REPAIRING MALFUNCTIONING (DOOR, IGNITION AND DECKLID) LOCKS. *TT
Service Bulletin Number: 98163
Bulletin Sequence Number: 981
NHTSA Item Number: SB6090873
Make: FORD TRUCK
Model: F150
Year: 1998
OOR
Summary: LOCKS FAILED. YD
Service Bulletin Number: 991210
NHTSA Item Number: SB606461
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EQUIPMENT:OTHER PIECES
Summary: FORD MOTOR COMPANY HAS RELEASED A PRIVATE LABELED MATERIAL TO BE USED FOR IRON PARTICLE / ACID RAIN SERVICE REPAIRS. *TT
Service Bulletin Number: 981617
Bulletin Sequence Number: 973
NHTSA Item Number: SB609754
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: FLOOR MAT INSTALLATION PROCEDURE SERVICE TIP. YD
Service Bulletin Number: 98168
NHTSA Item Number: SB609757
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INSTALLATION OF VINYL FLOOR MATS SERVICE TIP. AK
Service Bulletin Number: 982690
Bulletin Sequence Number: 359
NHTSA Item Number: SB603578
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EQUIPMENT:SPEED CONTROL
Summary: VEHICLES WITH MANUAL TRANSMISSIONS MAY HAVE A CUSTOMER CONCERN OF INOPERATIVE CRUISE CONTROL. *YC
Service Bulletin Number: 9811452
Bulletin Sequence Number: 362
NHTSA Item Number: SB603606
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: A CUSTOMER CONERN OF INOPERATIVE CRUISE CONTROL. *YC
Service Bulletin Number: 9864
Bulletin Sequence Number: 133
NHTSA Item Number: SB601312
Make: FORD TRUCK
Model: F150
Year: 1998
Component: EXHAUST SYSTEM
Summary: INFORMATION ON A BUZZING OR RATTLE NOISE FROM THE EXHAUST SYSTEM. *TT
Service Bulletin Number: 982010
Bulletin Sequence Number: 371
Date of Bulletin: 9810
NHTSA Item Number: SB603695
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: EXPERIENCING A EXPERIENCING A " BUZZING " OR " RATTLING " NOISE FROM THE EXHAUST SYSTEM. *YC
Service Bulletin Number: 981512
NHTSA Item Number: SB609551
Make: FORD TRUCK
Model: F150
Year: 1998
Component: FUEL:FUEL EMISSION CONTROL:CANISTER
Summary: A DIRECT REPLACEMENT PART FOR THE EVAPORATIVE EMISSION CANISTER AND BRACKET ASSEMBLY. AK
Service Bulletin Number: 9869
Bulletin Sequence Number: 134
NHTSA Item Number: SB601320
Make: FORD TRUCK
Model: F150
Year: 1998
Component: FUEL:FUEL INJECTION:IDLE SPEED CONTROL UNIT
Summary: CONCERNS WITH HESITATION, STUMBLE, SURGE, MISS, ROUGH IDLE, STALL AT IDLE. *TT
Service Bulletin Number: 981612
Bulletin Sequence Number: 972
NHTSA Item Number: SB609747
Make: FORD TRUCK
Model: F150
Year: 1998
Component: FUEL:FUEL INJECTION:UNKNOWN TYPE
Summary: FUEL MAY LEAK FROM THE SPRING LOCK COUPLINGS. YD
Service Bulletin Number: 9818
NHTSA Item Number: SB605568
Make: FORD TRUCK
Model: F150
Year: 1998
Component: FUEL:FUEL PUMP
Summary: SUBJECT REGARDING FUEL PUMP REPLACEMENT PROCEDURE - SERVICE TIP. *TT
Service Bulletin Number: 976011
Bulletin Sequence Number: 580
Date of Bulletin: 9711
NHTSA Item Number: SB605804
Make: FORD TRUCK
Model: F150
Year: 1998
Component: FUEL:FUEL SYSTEMS
Summary: EXPERIENCING DIFFICULTY DIAGNOSING VEHICLES WITH EVAPORATIVE FUEL SYSTEM DIAGNOSTIC TROUBLE CODES. *TT
Service Bulletin Number: 991410
NHTSA Item Number: SB608426
Make: FORD TRUCK
Model: F150
Year: 1998
Component: FUEL:THROTTLE LINKAGES AND CONTROL
Summary: SOME VEHICLES MAY EXHIBIT AN INDUCTION BACKFIRE ON ACCELERATIONS AND DECELERATIONS DURING ALL AMBIENT TEMPERATURES. *TT
Service Bulletin Number: 98259
Bulletin Sequence Number: 366
NHTSA Item Number: SB603647
Make: FORD TRUCK
Model: F150
Year: 1998
Component: INTERIOR SYSTEMS
Summary: SOME VINYL COVERED ITEMS SUCH AS DASH PANELS, DOOR TRIM PANELS, CONSOLES, ETC., MAY EXHIBIT A SMALL DENT, SCUFF, ABRASION AND/ OR DISCOLORATION RESULTING FROM ASSEMBLY, TRANSIT, DEALER PREP AND/OR CUSTOMER USAGE. *YC
Service Bulletin Number: 98317
Bulletin Sequence Number: 606
NHTSA Item Number: SB600599A
Make: FORD TRUCK
Model: F150
Year: 1998
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR
Summary: SUBJECT REGARDING THE MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATING AND DTC P0503 STORED IN MEMORY. *TT
Service Bulletin Number: 98419
Bulletin Sequence Number: 130
NHTSA Item Number: SB601280
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SOME VEHICLES MAY EXHIBIT A FLASHING TRANSMISSION CONTROL INDICATOR LAMP (TCIL) AND DIAGNOSTIC TROUBLE CODES (DTCS) 62,628, AND/OR 1728. *YC
Service Bulletin Number: 9858
Bulletin Sequence Number: 131
NHTSA Item Number: SB601298
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: THE MALFUNCTION INDICATOR LAMP (MIL) MAY ILLUMINATE AND DIAGNOSTIC TROUBLE CODE (DTC) P0503 MAY BE STORED IN MEMORY. *YC
Service Bulletin Number: 090308
Bulletin Sequence Number: 770
NHTSA Item Number: SB607711
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: MIL LIGHT ON WITH EVAPORATIVE DTC P0442, P0455
Service Bulletin Number: 99185
NHTSA Item Number: SB6090055
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/1998 AND WITH 4R70W TRANSMISSIONS MAY EXPERIENCE DELAYED OR NO 2-3 UPSHIFT, TRANSMISSION CONTROL INDICATOR LAMP ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE P0782 STORED IN MEMORY. *TT
Service Bulletin Number: 99234
NHTSA Item Number: SB6090131
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INFORMATION ON DIAGNOSING A VEHICLE WITH MALFUNCTION INDICATOR LAMP ILLUMINATED AND DIAGNOSTIC TROUBLE CODES P0442 AND P0455 STORED IN CONTINUOUS MEMORY. *TT
Service Bulletin Number: 0017
Bulletin Sequence Number: 122
Date of Bulletin: 0001
NHTSA Item Number: SB612254
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SUBJECT ON THE MALFUNCTION INDICATOR LAMP (MIL) MAY ILLUMINATE AND DIAGNOSTIC TROUBLE CODES MAY APPEAR. *MJS
Service Bulletin Number: 4619
NHTSA Item Number: SB615157
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SOME VEHICLES MAY EXHIBIT MALFUNCTION INDICATOR LIGHT ON WITH EVAPORATIVE DIAGNOSTIC TROUBLE CODES P0442, P0455 SET. *TT
Service Bulletin Number: 981610
NHTSA Item Number: SB609744
Make: FORD TRUCK
Model: F150
Year: 1998
Component: INTERIOR SYSTEMS:SEAT LATCH
Summary: THE SEAT BACK MAY NOT LATCH/ LOCK IN THE DESIRED POSITION AND REMAIN FOLDED FORWARD OVER THE SEAT CUSHION. YD
Service Bulletin Number: 99139
Bulletin Sequence Number: 650
NHTSA Item Number: SB606508
Make: FORD TRUCK
Model: F150
Year: 1998
Component: LIGHTING:LAMP OR SOCKET:BRAKE LIGHTS
Summary: CONDITIONS WITH THE BRAKE LAMPS INADVERTENTLY DISABLING THE BRAKE SHIFT INTERLOCK. *TT
Service Bulletin Number: BC2240970501
NHTSA Item Number: SB052779
Make: FORD TRUCK
Model: F150
Year: 1998
Component: MANUFACTURERS INFORMATION TO DEALERS
Summary: IF DIFFICULTIES ARE ENCOUNTERED INSTALLING ANY FORD DEALER-INSTALLED ADD-ON ACCESSORY, CONSULT THE FORD ACCESSORIES REFERENCE BOOK. *TW
Service Bulletin Number: 99111
Bulletin Sequence Number: 643
NHTSA Item Number: SB606433
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INFORMATION DESIGNED TO AID IN THE DIAGNOSIS, TESTING AND REPAIR OF NOISE, VIBRATION AND HARSHNESS (NVH) CONCERNS. *TT
Service Bulletin Number: 7106
NHTSA Item Number: SB6090455
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: INFORMATION REGARDING THE WINNERS OF THE EDSR OF THE MONTH QUALITY AWARDS FOR THE MONTH OF AUGUST. *MJS
Service Bulletin Number: 9943
Bulletin Sequence Number: 476
NHTSA Item Number: SB604751
Make: FORD TRUCK
Model: F150
Year: 1998
Component: POWER TRAIN
Summary: INFORMATION REGARDING REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS). *TT INFORMATIONON REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS). *TT
Service Bulletin Number: 13745
Bulletin Sequence Number: 127
NHTSA Item Number: SB612742
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SOME VEHICLES MAY EXPERIENCE A CONDITION OF NO 4 X 4 LOW RANGE ENGAGEMENT OR A STUCK IN 4 X 4 LOW RANGE. *MJS
Service Bulletin Number: 4631
NHTSA Item Number: SB615169
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: BRIEF INFORMATION ON VEHICLES EXHIBIT VIBRATION AT CRUISE OVER 50 MPH. *TT
Service Bulletin Number: 983070
Bulletin Sequence Number: 736
NHTSA Item Number: SB607364
Make: FORD TRUCK
Model: F150
Year: 1998
Component: POWER TRAIN TRANSFER CASE (4-WHEEL DRIVE)
Summary: SOMVE VEHICLES MAY EXHIBIT A BUZZ / LOW GROWL NOISE COMING FROM THE AREA OF THE TRANSFER CASE MANUAL SHIFT LEVER. *TT
Service Bulletin Number: 985128
NHTSA Item Number: SB613268
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SOME VEHICLES WITH ELECTRONIC SHIFT ON THE FLY 4X4 SYSTEMS MAY STICK IN 4X4 LOW. *TT
Service Bulletin Number: 13505
Bulletin Sequence Number: 146
NHTSA Item Number: SB614630
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: ALL 4X4 VEHICLES WITH ELECTRONIC SHIFT ONTHE FLY TRANSFER CASES WILL DISPLAY CONTACT PLATE PIDS OPPOSITE OF THE 1999 OR EARLIER WORKSHOP MANUAL INDICATES WHEN USING NGS WITH 15.0 LEVEL OR LATER SOFTWARE. *TT
Service Bulletin Number: 5128
NHTSA Item Number: SB615325
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SOME VEHICLES WITH ELECTRONIC SHIFT ON THE FLY 4X4 SYSTEMS MAY STICK IN 4X4 LOW. ENGINEERING IS INVESTIGATING. *TT
Service Bulletin Number: 12905
Bulletin Sequence Number: 693
NHTSA Item Number: SB606937
Make: FORD TRUCK
Model: F150
Year: 1998
Component: POWER TRAIN:AXLE ASSEMBLY
Summary: SOME VEHICLES MAY EXPERIENCE AXLE WIND UP AND / OR CLUNKING, POPPING, RATCHETING TYPE NOISES WHEN MAKING CORNERING MANEUVERS ON VEHICLES EQUIPPED WITH A FOUR WHEEL DRIVE HI OR LOW RANGE MODE. *TT
Service Bulletin Number: 983074
NHTSA Item Number: SB607369
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: CONCERNS WITH AXLE WIND-UP AND / OR CLUNKING, POPPING, RATCHETING TYPE NOISES WHEN MAKING CORNERING MANEUVERS. *TT
Service Bulletin Number: 4628
NHTSA Item Number: SB615164
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SOME VEHICLES MAY EXHIBIT REAR AXLE NOISE. *TT
Service Bulletin Number: 6242
Bulletin Sequence Number: 703
NHTSA Item Number: SB607036
Make: FORD TRUCK
Model: F150
Year: 1998
Component: POWER TRAIN:AXLE ASSEMBLY:HOUSING:AXLE SHAFT
Summary: EXPERIENCING A VIBRATION AND / OR TRANSMISSION EXTENSION HOUSING BUSHING DAMAGE. *TT
Service Bulletin Number: 99241
NHTSA Item Number: SB6090182
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: ON 4X2 VEHICLES WITH 4R70W AND 139 INCH WHEELBASE, A VIBRATION FROM TRANSMISSION AND / OR A TRANSMISSION FLUID LEAK FROM THE EXTENSION HOUSING SEAL MAY OCCUR. *TT
Service Bulletin Number: 13125
Bulletin Sequence Number: 902
NHTSA Item Number: SB609044
Make: FORD TRUCK
Model: F150
Year: 1998
Summary: SONE POLICE VEHICLES AND OTHER VEHICLES WITH 4R70W MAY EXHIBIT A VIBRATION AND / SONE POLICE VEHICLES AND OTHER VEHICLES WITH 4R70W MAY EXHIBIT A VIBRATION AND / OR TRANSMISSION EXTENSION HOUSING BUSHING DAMAGE FROM SUSTAINED HIGH SPEED OR TRANSMISSION EXTENSION HOUSING BUSHING DAMAGE FROM SUSTAINED HIGH SPEED OPERATION. *TT OPERATION. *TT
