F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-04-2001, 03:06 PM
Question Transmission oil change?
hi wondering if you guys could help. would changing the tranny oil on an expidition be the same as in the f150? i got a EB 4x2 w/ 5.4L. if so could someon give me a step by step? thanks. are there any other better tranny filters out there besideds the motorcraft? thanks for th help...
Old 03-09-2001, 10:10 PM
Vehicle: 2000 Ford F-150 7700 4x4
Send a message via ICQ to Y2K 7700 4x4
Post
The stock filter appears very capable (absent any way of actually measuring it's filtering ability). I think I read that the gasket is reusable (o-ring???).
Y2K™ Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Old 03-09-2001, 10:27 PM
Send a message via ICQ to fordtec2001
Post
the trans pan gasket is reuseable make sure the o ring from the old filter comes out with the filter when removing it from the trans
you can remove the plug in the bell housing to get to the drain plug for the torque converter and replace the fluid start the with 8 qts of mercon not mercon 5 then start the engine and pout the rest of the fluid run it thur the gears reverse and forward gear a few times then check fluid level it should take about 14 qts of mercon
Old 03-10-2001, 07:25 AM
Smile
thanks for the help. i really appreciate it.
Quote:
<font face="Verdana, Arial" size="2">Originally posted by hbbus580:
hi wondering if you guys could help. would changing the tranny oil on an expidition be the same as in the f150? i got a EB 4x2 w/ 5.4L. if so could someon give me a step by step? thanks. are there any other better tranny filters out there besideds the motorcraft? thanks for th help...</font>
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
