Bleeding the clutch
I'm experiencing the same problems that some of you are. I've got a '97 with about 82k. My clutch isn't slipping or anything like that, it's just the the pedal is less resistant. Could it be that I need a new master cylinder, need to bleed the system, or is it actually the clutch?
If anyone has any ideas, please let me know. I'd sure appreciate it!
Shagginwagon,
Sounds like you have a similar problem to what I had. It's hard to say if you replace the master cylinder and correctly bleed the clutch it will definitly fix your problem. But if it doesn't you have narrowed your problem down to the slave cylinder for under $65.
Lightening_R,
There is a very good chance that a new master cylinder will help the throw from 1st to 2nd. Have you ever had work done to the clutch before? And, does the master cylinder stay full, or do you have to add fluid occasionally? How many miles do you have on your truck? Have you checked the mechanical linkages yet?
Lightening_R,
Shagginwaggon,
I only want to add that it is important to get all residue out of the system. Like I said, It took almost a full quart of brake fluid before mine looked clear. If any air gets into the system from not keeping the reservior topped off, you have to start over. Hope this helps.
Cowboykent,
Thanks for the reply. I went home last night and bleed the system. Not quite sure if I did it correctly. I got a black residue come out through the tube. Maybe it's coming from the tubes or the black "plunger" from the master cylinder?
Clutch pedal feels a little better, but I'd like to have it a little tighter. I'm going to test it out for a few days, then I'll probably go get a new master cylinder.
Appreciate the advice. If you have any other suggestions, please keep me informed.
Thanks again!
Thanks again!
i hate manual trannys
HELP!!!! ok i just bought a 89 f150 4x4 4 speed 4.9L. the clutch went all the way to the floor and u had to stand on it to go into gear but it went, i got it home and replaced the slave cylinder and i lost all pressure after several bleeding attempts i went ahead and replaced the master cylinder also, now after bleeding i have little pressure and the clutch comes up less than half way, and it deffinetly wont go into gear..besides these plastic parts that are junk, can anyone suggest a fix? when i bleed the system i do the gravity and then bleed like u do brakes,open the bleeder screw push clutch pedal to the floor close bleeder screw and then check fluid level... but this doesnt seem to work i have done it alot...am i doin it right? PLEASE HELP!!!!
BTW, dont be hating on something due to user error
