98silverf150,
It is normal if the vehicle is still moving. See the problem is the way the tranny is stopped from moving.
If you are in neutral the transmission output shaft should not be moving or if it is it is very slow. The input shaft of the T-case is not moving so some grinding or clunk will occur. If you left it in drive the tranny output shaft would be turning and a rather large jerk would be felt when it was connected to the stationary T-case input shaft. Now to further complicate things where is the grinding coming from? Is it heard after you shift or when the shifter reaches its limit of travel?
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
BFG 285/75 R16 MTs,
Borla Cat Back, Headman Headers,
Modified Air Cleaner Outlet Tube
and air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
