F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-15-2001, 06:53 PM
JDF JDF is offline
Vehicle: 2001 FORD F150
Exclamation No O/D when cold?
I have been noticed that when it is below 40 degrees, the tranny won't shift into overdrive until it has warmed up. It usually only takes 5 minutes or a few miles but is this normal? When I leave the office, I'm right on the highway so it is very noticeable.
Any ideas folks?
2001 F150 XLT SC SPORT 4X4 FLARESIDE
* Black
* 4.6
* Auto
* awesome factory 10 spoke 17" wheels
* "MAN"ual shift 4x4
* 3.55 Limited slip
* Captains chairs W/console
* Factory tube steps
* Slider
Old 02-16-2001, 12:00 AM
Post
Mine is exactly the same. I believe this is done to reduce emissions until the engine is warmed up to a pre-determined temperature. I consider this "normal" and wouldn't worry about it.
Old 02-17-2001, 10:12 AM
Post
Same condition here. Believe it's normal.
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto, 4.10's, Mag-Hytec diff. cover, Magnacharger supercharger, K&N FIPK, Superchip, Gibson single cat-back, 80/100w German head lamps, 80w amber fog lamps, Warn HS9500i winch with semi hidden mount, Wrangler dual battery kit with red & yellow top Optima batteries, 285/75R16 Goodyear MT/R's, 16x8 Center Line Hell Cats (JUNK WHEELS), Rancho RSX shocks, B&M deep aluminum trans pan, Rhino bedliner. Needs one more door.
http://hometown.aol.com/ninetyeightfword
Old 02-17-2001, 03:46 PM
Question
Can't say as though I've experienced this . . . my OD will always trun on in cases where I want it to (usually I drive with it off . . . so I have to turn it on before it will engage . . . highway, etc.).
This is all year . . . it doesn't change when it gets cold . . . today it is around
-10F
Old 02-17-2001, 06:51 PM
Thumbs up
Are you guys sure it's not just the torque converter not locking up? In extreme cold (not 40;lower), mine still goes into 4th gear/overdrive, but the torque converter does not lock up until it's warm? It may feel like another gear, but it's not. If so, this is normal.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old 02-18-2001, 01:57 AM
Vehicle: 2000 Ford F150
Post
It's not just Ford. My father has a Saab 9-5 w/the annoying shift up light. At a steady cruise in fourth when the engine is cold, the shift light is off til the engine hits a certain temp. The Auto heat/fan kicks on at the exact same moment the upshift light comes on. I just wish I could default my O/D to off when I start the truck.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
Old 02-18-2001, 11:40 PM
Vehicle: 1999 Ford F-150
Post
I have the same condition. I asked my service department and was told it's the torque converter that doesn't lock-up until around 100-120 degrees or so. I think I also read a reply somewhere on this board from Factory_Tech that confirms this. I have a buddy with a '92 with the AODE that does the same thing.
1999 F-150 XLT SC Stepside, 5.4L (replaced), 3.55 Limited Slip, Towing Package, Captain's Chairs, Bright Red
Added: K&N, B&M Deep Aluminum Tranny Pan, Westin Nerfs,
True Duals with FM 40DF's & 2.25" tail pipes,
JVC CD Player, Pioneer 6x8 3 ways, 12 disc add-on CD changer
Old 02-19-2001, 03:42 PM
Post
JDF,
Same condition here. It's programmed that way.
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, HD electrical and cooling, power seat, Rhino Liner, Extang Classic tonneau cover, Mobil 1. Man, I got it all! (New Jersey)
Old 02-20-2001, 12:13 AM
Vehicle: 2001 Ford F150
Post
I used to work on GM transmissions and it was the case that the engine required warming up before lockup would occur. I am sure that it is the same here.
2001 F-150 Lariat SuperCrew, Dark Highland Green / Arizona Beige, Medium Parchment Leather (Captain's Chairs), 5.4L V8, 6 CD Changer, Rear Entertainment System, Rear Slider, 3.55 Limited Slip, Tow Package, Superchip, AirForce One FIPK, Bedrug, Extang Tuff Tonno III, DRLs, Bed Extender.
Next Mods - 01L Headlights and Corners, Gibson Exhaust, Headers, Hellwig Anti-Sway, Shocks, Bug Deflector, Fog Lights, White Face Gauges, & New Speakers!
Future Wish List - Magnacharger!!
Old 02-21-2001, 01:56 AM
JDF JDF is offline
Smile
Thanks guys.
Another mystery solved.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
