F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-12-2000, 08:20 PM
Location: Houston, by way of every major city in America.
Vehicle: 1998 Ford F-150
Send a message via AIM to 98SCREAMER
Post slow speed OD slippage.slip yoke TSB a fix?
I have noticed that if I forget to turn off the OD when I exit the freeway,the next time It
shifts from 2 to 3 the trans sort of slips and then when it engages,there is a soft
clank. This also happens when I'm on a surface road and do a partial stop in second,then accelerate. It never happens
when the OD is off. Only when It is running in OD on a surface road(30 to 45mph) Change the fluid as a start? Then what next? I don't tow with it,BTW
Thanks for any help and suggestions,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
Hoping for deliverance from door crack hell.
Old 10-14-2000, 02:20 PM
Cool
I had the same problem when accelerating from a stop as did others on the board.
Anyway, the fix was to lubricate the slip yoke. You have to take the driveline off to get at it. My dealer did it and they said it was a pretty simple procedure. Just for you info the new issue of Truck Trend mentions this in the letter section near the end of the magazine. TSB# 96-23-20 may relate to this problem.
There are also some threads on page 2 of this forum that may help you . . . look for the message "Rand the slipping feeling" posted by me.
Good Luck !
Old 10-14-2000, 06:43 PM
Talking
Thanks,Cougar guy
I hope this helps me,it's not that bad,but
it does bother me that it happens only when the OD is on and only at the 2 to 3
shift point. Or if you brake in third down to
about 30mph,and then reaccelerate. The
engine rpms don't go up,but the power just isn't all there until it does the clank/thud thing. then it goes great.......98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
