F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 04-04-2000, 02:04 AM
Talking E4OD and 4R70W return line fittings - which?
The book says the E4OD rear fitting is the return (back from cooler, into trans).
And the 4R70W Lower fitting (has one over the other) is the return for it.
Are these correct? The books sometimes have mistakes.
Old 04-04-2000, 07:05 PM
Vehicle: 2000 Ford F-150
Thumbs up
Generally the fitting that is closest to the bellhousing (converter) is converter out.
On ones that have the fittings stack'd atop of each other if you look closely you will see that one is closer to the bellhousing (converter) than the other.
2000 F-150 Lariat, Flareside, Black, SC, FOxFO, 5.4L, 3.55, Garmin Street Pilot Color GPS
Old 04-04-2000, 07:39 PM
Vehicle: 2005 Ford F250
Post
Assuming you're installing an aftermarket cooler- the bottom line from the radiator is the return line.
Old 04-04-2000, 10:25 PM
Vehicle: 1998 Ford F150
Post
I just installed a cooler on my truck and it happend to be the lower line as the return one. I took off the top line and turned the truck over for about 2 seconds to find out if the fluid came from the line, or the radiator. It came from the line, hence, the lower line is the return line.
Hope this helps.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
