No, I have an '97 F-150 Lariet 4X4 8Cyl 4.6L. My original entry is under suspension 3-10-00 "More Cluncking Noise". The noise sounded so much like ball joints or drive shaft/cv joint that I was sure that was the problem. I finally figured out how to simulate the noise when I was at an angle going over a speed bump. The truck rocked and made the noise as I was going over the bump at about 30 Degree angle. If you can duplicate the noise with the engine off, without going over a bump and someone underneath the vehicle to isolate the noise, you will find the problem.
Rey
