The shop manual says that the torque converter drain bolt must be replaced with a new one if it is removed. Has anyone had any trouble using the original bolt after draining? Maybe some thread-lock would be appropriate?
120,000 plus miles with 4 trans fluid changes including 4 torque converter fluid changes and the same drain plug with no problems.
Black 1997 F-150 4x2 Supercab Flairside with HD tow package, Sunroof.
2002 Lightning headlights.
Steel Horse billet grill with Blade Runner (I just love chrome).
Prestiege air dam.
4.6L with Superchip, K&N Generation II modified to use with Supercharger, Accel Coil Pacs, Troyer fans, Troyer trans cooler, Cat back Exhaust with Flowmaster Super 40 2 1/2" in and Duel 2 1/2" out with 3 1/2 Stainless tips out the back.
S.E.C. Polished alloy wheels, Style 27 (17X8) with 265/70-17 Bridgestone Dueler A/T Revo’s tires. Hellwig 1 7/16 front and 1 1/8 rear bar. Eaton Limited slip, 4.10 Ford Racing gears, TrickFlow rear diff support girdle.
Pioneer head unit with Cerwin-Vega 5x7's all around and Rockford Fosgate Sub in custom box with 300 watt RMS amp "THUMP-THUMP".
I reused mine with no problem and it has been a year since I changed the fluid.
__________________ 2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Air Force One FIPK, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/auxiliary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil, build 7/2000
Originally posted by Tiger I would add though that it seems to have rather fine threads and might be easy to strip.
True, but you could easily strip a new one with fine threads also. I put mine in and touqued to spec with no problem.
2000 F-150 XLT Sport, Silver 4-door Supercab StyleSide
Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires, 3.55 Open, 4.6l V8,
Automatic Trans (First one in 20 years)
In-Dash Single CD Player, 60/40 Split bench - dark graphite
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
