firedog,
The Transgo kit is a shift kit. It will change the way the transmission shifts. If it is just the shudder problem you want to fix, then the Sonnex valves should fix that (mine did but I also did the shift kit).
It is not hard to do the valves or the shift kit but the instructions from Sonnex alone are poor. If you know someone who has done the Transgo kit then get the tape and watch it. It will help a lot to guide you thru the removal and replacement of the valve body.
Black 1997 F-150 4x2 Supercab Flairside with HD tow package, Sunroof.
2002 Lightning headlights.
Steel Horse billet grill with Blade Runner (I just love chrome).
Prestiege air dam.
4.6L with Superchip, K&N Generation II modified to use with Supercharger, Accel Coil Pacs, Troyer fans, Troyer trans cooler, Cat back Exhaust with Flowmaster Super 40 2 1/2" in and Duel 2 1/2" out with 3 1/2 Stainless tips out the back.
S.E.C. Polished alloy wheels, Style 27 (17X8) with 265/70-17 Bridgestone Dueler A/T Revo’s tires. Hellwig 1 7/16 front and 1 1/8 rear bar. Eaton Limited slip, 4.10 Ford Racing gears, TrickFlow rear diff support girdle.
Pioneer head unit with Cerwin-Vega 5x7's all around and Rockford Fosgate Sub in custom box with 300 watt RMS amp "THUMP-THUMP".
http://www.f150online.com/galleries/....cfm?gnum=1496
Powerdyne Supercharger at 9lbs, 42LB injecters, 90MM MAF, Superchips 4 program chip.
JBA Jet coated headers
How fast am I you ask;
"Slower then John Force... Fast enough for me and exactly as fast as I can afford"
NOW 9 YEARS OLD AND STILL TURNING HEADS!!
