Just received my Transgo kit and was looking over the instructions and tape. I've turned wrenches for years but I've never done a shift kit before so I hope I don't screw it up!! I noticed other posts mention of setting different levels, just how exactly do you do this?
I just received mine as well and have secured the oil, filter and drain plug kit. I do have a couple of questions that maybe some of the other folks out there can answer (since I went cheap and bought the kit w/o the video).
1. The TransGo kit came with two orange seals, about 1.5" in diameter, bagged seperately. There isn't any explanation as to where these are to go, except for a half sheet of paper stating basically, install these correctly or they won't work." What are they for?
2. Since I have a 4wd with a 4R70W, there is a mini-sump in the bottom of the pan. I assume, judging by the new filter, that the filter's intake "snout" extends somewhat into this area. Would it be safe to install the drain plug in the center of the bottom of this sump?
3. If it is safe (#2 above), has anyone ever drilled the sump prior to dropping the pan so as to allow the oil to drain out there? I know that it will run all over the drill until I get the bit out of the hole, but better that than have it go God knows where when I drop the pan.
JPBigony,
In my kit the two large O rings were for "if you have the transmission out", I did not install them. Also, maybe someone in your area would be willing to share their instruction video with you. It really helps in the removal and reinstallation of the valve body if you have never done it before. Post your area and see what replies you get.
I have my transmission drain in the "snout" but not centered. It is more to the front drivers side at about 10 o’clock and worked fine. I think it is a great idea to drill first to remove the trans fluid (where were you when I did mine). I think many will benefit from that idea in the future. You may want to use a smaller drill bit to save your drill some mess, and then open it up later. Remember to leave room for the drain valve on the inside.
There are quite a few posts here with what stage to use. Mine is drilled between stage one and two using my own drill bit. It will chirp second at WOT but not if I remove the Superchip (I had it out while on vacation). The shifts are firm but comfortable while easy driving.
The best of luck to both of you.
Black 1997 F-150 4x2 Supercab Flairside with HD tow package, Sunroof.
2002 Lightning headlights.
Steel Horse billet grill with Blade Runner (I just love chrome).
Prestiege air dam.
4.6L with Superchip, K&N Generation II modified to use with Supercharger, Accel Coil Pacs, Troyer fans, Troyer trans cooler, Cat back Exhaust with Flowmaster Super 40 2 1/2" in and Duel 2 1/2" out with 3 1/2 Stainless tips out the back.
S.E.C. Polished alloy wheels, Style 27 (17X8) with 265/70-17 Bridgestone Dueler A/T Revo’s tires. Hellwig 1 7/16 front and 1 1/8 rear bar. Eaton Limited slip, 4.10 Ford Racing gears, TrickFlow rear diff support girdle.
Pioneer head unit with Cerwin-Vega 5x7's all around and Rockford Fosgate Sub in custom box with 300 watt RMS amp "THUMP-THUMP".
JPBigony,
I just noticed in your signature that you live in Bowie. I live in Manchester and work in Baltimore. Send me an Email with a phone number and maybe I can get a copy of the tape to you.
Make sure you put the rectangular bowl shaped screen back into the trans before you re-install the valve body (DOH).
Make sure you remember to remove the paper clip or cotter pin holding the EPC valve together after you bolt it to the valve body (DOH#2).
On mine, the picture in the directions did not exactly match my valve body for check balls. Before you dump them out, note (by picture or sketch) exactly where they are. Then you'll replace all but one of them!
2000 F-150 XLT Sport, Silver 4-door Supercab StyleSide
Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires, 3.55 Open, 4.6l V8,
Automatic Trans (First one in 20 years)
In-Dash Single CD Player, 60/40 Split bench - dark graphite
WLF,
Thanks for the info. Again I notice that you mention stage 1 and stage 2, I didn't find any mention of these stages in my Transgo kit. Are there more than one type of these Transgo kits?
The first drilling instruction is for drilling two holes in the valve body. The second instruction is for drilling the valve body plate.
It is this second drilling instruction when you drill the first hole in the valve body plate (cant remember if it is 1 or A) that you are given a choice of three different drill sizes. That is what determines how hard it shifts. The larger the hole, the harder the shift. Three drill sizes are provided and so three stages of hardness..
WLF,
Thanks!! I see where the instructions show to drill two holes in the body but it didn't mention any options, it just said to drill two .093 holes!! Now I understand your other post regarding the .093 drill bit. I guess it worked out to be the 3/32". Appreciate the help, I'll give it a go this weekend hopefully.
01screw,
It is not the .093 holes that are adjustable. They are in the valve body.
It is the first hole you drill in the PLATE. This is a seporate instruction and a different part of the valve body. The plate is the first thing removed from the valve body and has many holes in it. The instructions direct you where to find the holes that need to be drilled and what size to drill them.
The two holes in the valve body are .093. Do not drill them any other size...
If you don't see what I mean then when I get home today I will find the page on the instructions to refer you to.
WLF,
Wow, thanks for clearing that up!! I think I found what you're talking about, directions state exactly:
"Plate hole sizes"
#1 & 1A = .067
#2 = .067 Police-taxis-truck & mild street rod
#2 = 3-32" Hot rod with original converter
#2 = 1-8" with smaller diameter high stall converter
#3,4 and 5 = Leave as is.
#6 = 1/8"
I guess the option lies with the #2 hole. Sorry, I'll get this right sooner or later!! Better to ask stupid questions than to make dumb mistakes!!
Yea thats it. Must be the #2 hole then. That makes the difference in the three firmness settings. Mine is between th .067 and the 3/32 size.
Hope everything goes well. Have fun. Not really that hard of an install.
[url=Transgo Check Balls]
What do you mean by dump the check balls and then you'll replace all but one, I did not see any replacement check ball in my kit, the instruction page just shows where they are located but no other instructions, now I am
2000 F-150, S/C F/S 5.4lt Auto, 3.55 LS Upgraded to 4.10LS, M4x4, Capt. Chairs 6 way elec.,DELETED 6 CD,Class III towing hitch and package, etc,etc,.
Med Toreador Red
Born 03-27-00
Mods,
Superchip UAT2,Borla Anniversary Edition Split rear catback,K&NGen II or FIPK, BBK Trottle Body,Granattely Mass Air Flow,SVT Lightning 18" wheels,285/60/18 Pirelli Scorpion Zero,HellwigSway bar, Dark Walnut dash kit,Muth signal mirrors,White face gauge,Iridium Denso spark plug,Retrax Rolltop,Outland sport bumper guard,Firestone air springs,Ford OEM bug deflector,Underhood sound insulation panel,Piaa Plat. super white Bulbs,Catch All floor mats,Lund Back Draft tailgate spoiler,Pioneer DEH-P8400MP, CDX-677 CD Changer, Polk DX 7 rear and JBL GTO505 Component Speakers, Infiniy Kappa p10i sub, Steering Remote for H/U, Mute for cellular.
dragonboy,
There is one check ball that does not go back in.
I hope you did not put them all back in. If so, I hope you put in a drain valve while you had the pan down, you will need it.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
