F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-31-2002, 05:36 PM
Vehicle: 2000 Ford F150
Help - Trango Check Balls
Help. I'm almost finished my Transgo install, but the directions for the check balls doesn't match the actual valve body. 6 of the 7 balls or OK. The last doesn't make sense. See the directions attached and the pictures of the body itself. Please help quickly.
2000 F-150 XLT Sport, Silver 4-door Supercab StyleSide
Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires, 3.55 Open, 4.6l V8,
Automatic Trans (First one in 20 years)
In-Dash Single CD Player, 60/40 Split bench - dark graphite
MODS SO FAR
Gatorback Spray-In Bedliner, Llumar ProShield Window Tint
WMS Velocity Tube (removed due to hum), Black Westin Step Bars, Lund Trident Hood Deflector (removed to paint), Fumoto Oil Drain Valve, FlowMaster Delta Flow 50 muffler in place of stock, DeeZee Silver Series Black Single Lid ToolBox; Extang Black Max tonneau cover; Factory Tech Valve Body & Accumulators; 5-channel amp w/ 8" RF sub in custom box and 5x7 Pioneer speakers;Superchip MicroTuner model 1715
Old 08-31-2002, 05:37 PM
one last picture
Old 09-01-2002, 11:30 PM
WLF WLF is offline
Vehicle: 1997 Ford F150
I am not sure what your question is.
On my kit there is one check ball that did not get re-installed. I called transgo and they verified that I should have one check ball left over after the install. The oriface valve that is installed later (see my posts for problems I had) replaces this last check ball.
Hope this helps...
Black 1997 F-150 4x2 Supercab Flairside with HD tow package, Sunroof.
2002 Lightning headlights.
Steel Horse billet grill with Blade Runner (I just love chrome).
Prestiege air dam.
4.6L with Superchip, K&N Generation II modified to use with Supercharger, Accel Coil Pacs, Troyer fans, Troyer trans cooler, Cat back Exhaust with Flowmaster Super 40 2 1/2" in and Duel 2 1/2" out with 3 1/2 Stainless tips out the back.
S.E.C. Polished alloy wheels, Style 27 (17X8) with 265/70-17 Bridgestone Dueler A/T Revo’s tires. Hellwig 1 7/16 front and 1 1/8 rear bar. Eaton Limited slip, 4.10 Ford Racing gears, TrickFlow rear diff support girdle.
Pioneer head unit with Cerwin-Vega 5x7's all around and Rockford Fosgate Sub in custom box with 300 watt RMS amp "THUMP-THUMP".
http://www.f150online.com/galleries/....cfm?gnum=1496
Powerdyne Supercharger at 9lbs, 42LB injecters, 90MM MAF, Superchips 4 program chip.
JBA Jet coated headers
How fast am I you ask;
"Slower then John Force... Fast enough for me and exactly as fast as I can afford"
NOW 9 YEARS OLD AND STILL TURNING HEADS!!
Old 09-03-2002, 10:10 AM
Thanks, I understood that one check ball wasn't reinstalled.
My problem was that the diagram in the directions didn't match the valve body itself and that Transgo tech support was not answereing the phone on Saturday.
If I traced to where the directions said the check ball went, it was a large opening where I knew the ball wouldn't check anything. The check ball actually went where the screwdriver is pointing in the last picture.
On a now its funny note, I had to drop the valve body twice.... turns out I found a screen that should have been installed above the body in the transmission. Found its location after several minutes of searching.
Finished (at least I thought I had) the install Saturday night, but was not really impressed with the shifts - they didn't seem much better than stock.
Then, after the truck sits all day Sunday (I made my son drive me in his car to church), I wake up early Monday morning having dreamt that I left the paper clip on the EPC valve. Sure enough, it wasn't in the box.
Had to drop most of the pan and pull it out. Retighten, retourque, etc. Fill er up and take her for a test drive! What a difference. Apparently, with the EPC lifted slightly, the pressure can't build enough to make the shifts firm. With the EPC correctly installed, the shifts are firm and quick.
Not counting my fiascos with directions, screens and paper clips, the hardest part of the job was removing the plastic connector strip safely. I was paranoid about breaking it and having to find my way to a Ford dealer on a Saturday. Second hardest had to be using snap ring pliers with hands sufficiently lubricated by ATF!
MODS SO FAR
Old 09-03-2002, 01:33 PM
WLF WLF is offline
I feel your pain brother. I followed someones advise and got a good set of snap ring pliers. Still does not account for the still good trans fluid all over my hands no matter how much I tried to keep them clean. I finally got everything in and I guess you did too.
Glad it worked out well for you. It's amazing what we can do in our dreams...
Prestiege air dam.
Old 09-03-2002, 04:34 PM
I thought I had a good set of pliers. Made by channel loc. Still tough to "handle". At least ATF cleans up easily with soap and water - it certainly doesn't wipe of well with a rag! lol
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
