2nd gear?
mdelliott76
It almost sounds like you had it shifted into second manually
did you know in the transmission you have if you select 2nd there it will stay! it will not downshift so if you have it in second and try to a fast start it wont down shift like you would expect , maybe you already know this but it sounds like what you were describing was manually selected 2nd. just a thought , don't know if this helps , but I see you had not had a reply yet. and I know I have done this also without realising it! , Skully
