F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-31-2002, 01:08 PM
Vehicle: 2002 Ford F-150 5.4L
B&M Transmission Pan??
I just found a B&M transmission pan for the 4R70W. It's aluminum with the cooling fins along the bottom and holds 3 extra quarts!!! This is probably a dumb question but would this be a good investment worth the money??
Is changing the pan just as easy as changing the pan? There's no pickup or anything inside to worry about since the pan is alot deeper than stock?
I don't do alot (hardly any) towing but my concern on trans temps is when the converter unlocks (or locks if I got it backwards) going down the highway. It's really windy where I live and not uncommon to drive around like that for several miles. I couldn't believe what that caused after I got a temp gauge...WOW. Anyway, would like to help battle that some but didn't really have a need to change the coolers and all that.
'02 F150 XLT 4X4 SCrew. 5.4L
K&N FIPK/Amsoil Filter
Flowmaster 40 si/do Exhaust
325/70 16 Nitto Terra Grapplers
16X10 MB Motorsport wheels
4.10 Gears
Rancho 4" lift
Edelbrock Extreme Travel Resi Shocks
Autometer Carbon Fiber Oil/Trans Temp Gauges
Carbon Fiber Interior (www.dash-kit.com)
Peterson Fluid Sys. Remote Oil Filter
FTVB
Troyer Performance Electric Fans
Underdrive Pulleys
Amsoil Fluids Throughout
My SCrew'd Garage
Old 09-02-2002, 01:04 AM
Vehicle: 1999 Ford F150
It's a nice pan but verrrry pricey. If you're concerned about heat, then you are mych better of putting the oney into a cooler. You can get a nice B&M stacked plate for about a third the cost. If you already have a cooler, then don't sweat it.
As far as difficulty in relpacing, Piece of cake on a 2wd. Don't know about 4wd, may be a skid plate or some other obstruction.
99, XL, SC, SB, auto, 4.6L, 3.55LS 2wd.
http://home.att.net/~neilwood.pe/wsb...ome.html-.html
Old 09-02-2002, 04:43 PM
Do you have to use an extension for the filter? Or do you have to use a special filter? Sorry to butt in but was wondering the same thing.
Old 09-04-2002, 09:44 AM
I believe the pan for the 4R70W comes with an extension for the filter pickup.
Old 09-04-2002, 11:54 AM
Vehicle: 1997 FORD F150
I dont know if you have 4WD or not but if you do the rear of the pan is a really tight fit against the trans crossmember. One member here wound up trimming that side to make more clearance.
I tried doing a search for it but the search function does'nt like 3 letter words like B&M or pan so maybe someone will come forward with the relative details.
Good luck.
Old 09-04-2002, 07:42 PM
Mine is a 2WD. I heard that the B&M pan has aluminum pegs that come up from the bottom that the filter sits on. I don't know if it is true but it sounds better than using the extension. I'm afraid that extension might shake loose or not seal well. Maybe I'm just paranoid.
Old 09-05-2002, 09:12 PM
Vehicle: 2005 Ford F-150
I have an aluminum pan from www.performanceautomatics.com it is a nice unit. i havent put it on yet though. I dont think it is deeper than stock too much. but it has a drain plug and the cooling fins.
-steve
2005 F-150 SuperCrew FX4
Appearance - Nifty Coverall Floormats * Line-X Bedliner * C.M.I. Low Pro Black Toolbox * Back Carriage Works upper and lower grills * Front window tint * Depo Black Headlighs * Black tinted tail lights and 3rd brake light * Black 20" Factory wheels * 33x13.50R20 Super Swamper Iroks * 2 1/2 inch Autospring * Skyjacker Add-a-leaf
Audio/Security - Python 881XP Alarm/Remote Start * Infinity Kappa 680.1cs Components
Performance - Edge Evolution
Gallery
Old 09-06-2002, 12:05 AM
That link didn't work for some reson.
Old 09-06-2002, 08:43 AM
sorry, its www.performanceautomatic.com no s. I have thier Valve body for the 4r70w and tranny pan. the tranny pan is really nice probably really similar to the B&M. I am installing the VB soon. If you want pictures, i could get you some.
-steve
Old 09-06-2002, 07:22 PM
How does the filter mount in their pan? Does it use an extension? Thanks for taking the time to check for me.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
