F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-29-2002, 11:53 PM
Question Radiator fitting size?
Anyone know the fitting size for the transmission cooling lines at the radiator? Is it a flared fitting? NPT? I want to install a cooler but I need to know what adapters to get (flared to barbed, NPT to barbed, or what?) Any links to a site with that kind of info would be of great help.
Old 08-30-2002, 12:16 AM
Vehicle: 1999 Ford F150
3/8" inverted flare long throat. I was unable to find these fittings when I installed mine a year ago so just cut the line and spliced with hose. However, in the last week I was surfing for a cooler for my van and found a site that had similar fittings. See below. You'll have to contact them to see if they have 3/8".
http://www.drawtite-hitches.com/tran...cooler_acc.htm
http://www.bulkparts.com/MM001.ASP?pageno=1176
Might want to check Summit racing too.
99, XL, SC, SB, auto, 4.6L, 3.55LS 2wd.
http://home.att.net/~neilwood.pe/wsb...ome.html-.html
Old 08-30-2002, 12:51 AM
Thanks, Tiger! You da man!
Old 08-30-2002, 11:58 PM
Lightbulb
Just finished some research and made some measurements on the transmission line fitting for my radiator (2001 V6), it has 5/8" O.D. threads on the male fitting. The fittings are, as Tiger said, an inverted flare; however they are 5/8-18 thread (standard for 3/8" tubes). See the links below. bulkparts.com sells the Hayden adapters (#T395). Derale also makes them (PN 13025). And, as Tiger said, drawtite-hitches.com has them (PN 6442).
This is probably more information than anyone needed to know, but I'm making this post so I can find the info later, myself.
http://www.hydraulic-supply.com/pdf/1198.pdf
http://www.tompkinsindustries.com/threadpitchchart.asp
http://www.derale.com/transcooleraccess.shtml
Old 09-02-2002, 12:54 AM
Sorry, that was a brain-fart on my part. I was thinking about the tube diameter. You are correct.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
