F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-28-2002, 01:26 PM
Vehicle: 2000 Ford F150
Freeplay in clutch pedal.
Good morning, I have a 2000 F150 4.2 5-speed with 38,000 mi. Over the last 2000 mi. the freeplay in the clutch pedal has increased. Oddly, it changes over the course of the day. In the morning, when the weather is cool, there is no freeplay. Later in the day, as the temp. increases, so does the freeplay, up to approx. 1.25 in. before I feel pressure on the pedal. The fluid level is correct. It does not leak. I'm thinking 'slave cylinder'? Has anyone else experienced this? What was the fix? Thanks for any input. Mike
Old 08-28-2002, 07:08 PM
Vehicle: 2007 Ford Edge
Hello and welcome.
It may be something major but it also may be bushings in the pedal assembly. You might want to see if it looks like that is where the problem originates.
Good luck!
Tom
'07 Ford Edge
Ford says the Edge is a truck/SUV.
Click here to see the Ford trucks that I've owned
Click here to see the newest pics
Old 09-05-2002, 06:06 PM
216 216 is offline
Vehicle: 2001 Ford F150
Mike,
I have an 01 4.6L. At about 28,000 miles, the clutch pedal started behaving just as you described (alot of slop sometimes, absolutely no slop others). I found that when it started getting play in it, I could remove the play by pumping the pedal quickly several times (when pumping would only push until I started getting resistance, not all the way to the floor). Anyway, I took the truck in to the dealer and they thought it was a slave cylinder. Since replacing the slave on 4.6 means dropping the tranni, I ordered a master cylinder and installed it myself ($50). I figured that I might as well try the master first since it was easiest. Anyway, that seems to have solved the problem completely (knock on wood). Hope this helped.
Chuck
Old 09-06-2002, 04:44 PM
My clutch pedal does that too. But it's only like 1/4". And I still have that 2nd to 3rd gear rake when shifting fast under hard excelleration(sp??) Sheesh!
Old 09-06-2002, 06:48 PM
short throw shifter?
We are still waiting to hear from Hurst that they will be coming out with a short throw shifter for our trucks. It won't eliminate the grind/rake but it should help.
Old 09-11-2002, 12:37 PM
I have a 2001 Sport XLT with the 5 spd 4.6 and had the clutch play problem, the dealer replaced the Clutch Master Cylinder (their terminology-may be the same as slave cylinder-not sure), anyway the problem is gone.
Tranny still feels like there is gravel in it and the 2nd - 3rd gear rough shift comes and goes. I saw mention of a different shifter helping the problem and I also hear factory may have put non synthetic fluid in the tranny instead of synthetic. Any definite fixes
Old 09-11-2002, 09:41 PM
Vehicle: 2007 Ford F150
Ok, first I admit I don't know much at all about trans. I have the 4.2 with 5-speed. I have read here some of you talking about shifting problems from 2nd to 3rd. My truck has approx. 26,000 miles on it. It sometimes feels like it don't want to go into 3rd from 2nd and a few times even mashed the gears a bit (the slightly grinding sound) and I did have the clutch in all the way.
My question is; is this not so uncommon for the 5-speeds and I should just live with it? Or should I be taking it into the dealer for repair? If so, what would they repair?
Old 09-11-2002, 10:36 PM
Vehicle: 1999 ford f-150
Send a message via AIM to schoolbus
Unhappy mine too
o1;
at about 25000 miles my truck started grinding into 3rd and i got scared so i took it to the dealer and they replaced the 3rd gear syncro. it was under warrenty , but now it is doing it again and i got 66000 miles~~way out of warrenty
hope this helps
moose
99 f150,4.2 V6,5-spd. volant intake, flow si/do exit before rear wheel, carpets,husky liners extang tonno cover, apc clear corners and carbon fiber tails, apc projector headlights, nu image white face gages and a/c panel, kenwood 519 head,sirius satalite radio, kenwood amp, infinity and MTX speakers
2007 dodge ram reg cab short bed 4.7 v8 6-speed 4x4-extang express cover
http://www.f150online.com/galleries/....cfm?gnum=2250
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
