F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-28-2002, 12:55 AM
Vehicle: 2005 Ford F-150
PA valvebody is here!
I got the PA valvebody today. it came with springs for the 1-2 and 2-3 accumulator as well. the only problem is it did not come with spacers fot the newer 1-2 accumulator style. so i am going to try to get some washers to space it like the Baumann kit has. the VB looks like it is really good quality. i am going out of town this weekend so it may be awhile before i get it installed but i will let you all know how it goes. i think as long as i can find the right spacing washers there should be no problems. i guess if i cant find the right washers i could leave the accumulatoers alone... but... im going to try to get them. Im not sure why they werent included because the VB is for trannys after 96 and they changed the 1-2 accumulator in 97. anyway. it came with a spring for the 2-3 too which is nice. the baumann didnt have that. i also ordered the deep aluminum trans pan. it is nice, but i dont know where i can put the circular magnet now. i guess i will just leave it out? ill try to post pics sometime later this week.
-steve
2005 F-150 SuperCrew FX4
Appearance - Nifty Coverall Floormats * Line-X Bedliner * C.M.I. Low Pro Black Toolbox * Back Carriage Works upper and lower grills * Front window tint * Depo Black Headlighs * Black tinted tail lights and 3rd brake light * Black 20" Factory wheels * 33x13.50R20 Super Swamper Iroks * 2 1/2 inch Autospring * Skyjacker Add-a-leaf
Audio/Security - Python 881XP Alarm/Remote Start * Infinity Kappa 680.1cs Components
Performance - Edge Evolution
Gallery
Old 08-28-2002, 04:13 AM
Vehicle: 2005 Ford Mustang
Put a little dab of JB Weld on the magnet and place it around the drain plug.
G
Old 08-28-2002, 08:43 AM
thanks factrory tech, i will definately do that. I was also wondering if it is necessary to get the 4x4 filter. i just got a new one so i would rather not get another. I dont think the new pan is much bigger than my factory one. i think the current filter will work fine. but i was just wondering. Also, the Valvebody is for an AODE. 1996 and up. I was told that it works for all 4r70w trannys too. It looks exactly the same as my current VB. I just wanted to verify that it will work properly. also, is there any tricks to switching the selinoids over to the new VB? do you just unbolt them and bolt them up to the new VB, or do they have to be lined up. The only dissapointment i have with PA is that there was practically no instructions with the kit. I dont think i will have any problems because i did the baumann kit before and i still have the instructions. but if i didnt i would have no clue. i think i will probably put the VB in next week sometime. ill let you guys know how it goes. thanks for the help factory tech.
-steve
Old 08-28-2002, 11:40 AM
Vehicle: 2002 Ford E350
The last year the AODE was produced was 1995. It was completely replaced by the 4R70W.
Mark
Old 08-28-2002, 02:16 PM
Vehicle: 1997 FORD F150
Just a small caveat for ya 2000F150HD. If the accumulator springs did'nt come with any spacers it might be because the springs are calibrated to work properly without any spacers.
Maybe a phone call to the PA people is in order to verify that fact before you add washers.
Good luck.
Old 08-29-2002, 12:51 AM
Mark-
The 4R70W is a newer version of the AODE it uses the same Valvebody. and is somewhat the same, just really revised, mostly internally. i dont know much about this, and i am not going to pretend to. but i do know that they use the same VB. and about the springs. i checked them according to the stock top spring that i have from a previous shift kit install..... and the spring is too short. i think i can find the right spacers for the spring though. The only other thing i am wondering now is about removing and replacing the selinoids. but i was told that it should be really easy. now all i ahve to do is find the spacers then find some time to put it in. hopefully next week.
-steve
Old 08-29-2002, 02:10 PM
Vehicle: 2002 Ford F150
I wouldn't say it's a "newer version" of the AODE considering the AODE was made from 92-95 and the 4R70W started production in 93. The only differences in the two trannies is the gearset, 4R uses a better output shaft material and a larger outside diameter slip yolk which requires a different extension housing. Towncar, Grand Marquis, CrownVic and 94-95 Mustang were the only vehicles that came with AODE's factory.
Seabass
Old 08-29-2002, 08:28 PM
seabass, like i said i dont know to much about it. sorry about the mistake. and thanks for clearing up the diffrences. I am just learning about trannys. I will hopefully get the PA valvebody in next week or next weekend. ill let you know how it shifts. i cant wait.
-steve
Old 09-30-2002, 05:58 PM
Vehicle: 2005 Ford F150
Have you gotten your new valve body in yet?
Thanks.
- Jay
Vehicle
2005 F150 XLT SuperCrew 4x2, 5.4, 3.73LS
Mods:
15% tint
Pioneer DEH-P8MP
Kicker DS68 Coaxials (Front, Rear)
Ground Force 2" Drop Shackles
STX AC Vents (XLT vents for sale)
Old 09-30-2002, 09:42 PM
Factory_Tech. Your reply to 2000 harley about the factory round magnet that goes in the tranny pan was to install the round magnet around the drain plug. He said that he had a deepened alum pan. I would guess that it is the B&M deep pan. It has two round supports that stick up from the floor of the pan. I just did the Transgo Valve body kit with the B&M pan. What about putting the donut magnet around one of those supports since the B&M has a magnified drain plug?
http://www.f150online.com/galleries/...y.cfm?gnum=578
1997 F-150 LARIAT S/C 4x2 Styleside...Pacific Green Exterior/Silver Frost Accent...4.6L Triton (Romeo)...Auto(4r70W)...3.55 Limited Slip...Trailer Tow Pkg...Remote Entry w/ Anti-Theft...Power Everything...
FORD ACCESSORIES Wheel Locks...Molded Vinyl Floor Mats...Sill Plates (Look Great!)...Molded Mud Guards...
AFTERMARKET Bedrug Bedliner...Lund Bug Shield...Ventshield Side Ovals... APC Clear Taillite Covers...A.R.E. Fibreglass Tonneau Cover w/custom ozite liner...22 Piece Burl Wood Dash Kit...Custom Tweed Hood Insulator Pad...Westin Chrome Step Bars...
PERFORMANCE OPTIONS SVO Lightning Wheels w/ Yokohamo 285/50/18 AVS-ST Tires...Optima Battery...Evergreen F.I.P.G...Superchip YSL2 Flip Chip...Magnacharger Supercharger...Flowmaster 17137 S.I.D.O Catback Exhaust w/ Stainless Tips
STEREO Premium Ford Head Unit...Pac Lineout Convertors...Coustic 3E Crossover...JBL GTQ400 & GTQ200 Amps., Behind Full Functional Backseat...2x JL Audio10W4 Subs ...4 Pioneer 3-Way 6815's In Doors...
WHAT'S NEXT? JBA Headers...Y-Pipe Modification...Pulley Set...Maf & Throttlebody Upgrades
Old 09-30-2002, 11:15 PM
Vehicle: 1995 Ford F150
Send a message via ICQ to beastie
I am thinking about either a PA valvebody or TransGo, tell us how the PA is. I want to do it right the first time.
Old 09-30-2002, 11:26 PM
Beastie,...i put the Transgo in this past Wednesday nite. Five hours spent raising truck, draining the fluid ( t.c. & trans & lines), removing the V.B., cleaning and swapping parts, drilling, etc. Finished the next am by doing the accumalator springs & installing the valve body plus the B&M pan. 15 quarts later drove her away. Big improvement but no chirp. Cleaned the corrosion on the neg. post & then test drove the truck again. WOW! was able to bark, chirp, break em loose, whatever ! Definately worth the $$$ for this mod. She slams when you are into it and smooth when you OLD LADY it.
Old 09-30-2002, 11:37 PM
Do you have a Superchip? And cleaned what negative post???
Well Boss Lariat, I dont mind telling you that I'm just a little jealous of you. I did the Transgo kit and used the second setting and still cant get a chirp out of the tires. The shifting is greatly improved but still no chirp on the 1-2 shift.
Maybe after the microtuner I'll get that little sqeal of protest from the rear tires? Good job on the install, glad you're happy with it.
Good luck.
BTW, nice truck ......... it sure does look familiar.
1997 Lariat Supercab
Pacific Green/Silver
Flareside
4.6 liter/Romeo
2WD / 4R70W auto
4.30 LS
Cold airbox and silencer mod
MAF mod
K&N drop in
Transgo shift kit
B&M Supercooler transcooler
Lakewood slapper bars.
Expedition bumper swap
ARE LS II cover w/ carpet lining
ventshades
Viper alarm w/ remote start
More to come :^
Click here to check out my pics.
Old 10-01-2002, 12:05 AM
Wo man. If you went level 2 with the transgo, you are really going to get some HARD tire chirping shifts. The light thottle shifts might actually be too tough. Mike said that 80% of the people with a chip and transgo kit on lvl 1 will ge ta nice chirp. He said with a chip and transgo on lvl 2 it will be harsh shifts. But maybe since you have the microtuner, you can tune down the shift firmness, I just dont know how much you can tune them. Good luck
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
