F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 08-20-2002, 08:38 PM
Which shift kit should I choose?
I am currently interested in buying a shift kit for my truck, and was wondering which of these two I should go with: Baumann or TransGo? Right now I am a little more interested in the Baumann because it has more than just three settings to choose from. Which one do you guys think would actually be the better choice? I plan on buying one or the other within the next few days, so any opinions would be greatly appreciated.
Old 08-20-2002, 08:55 PM
Vehicle: 1997 Ford F150
Send a message via Yahoo to svtoby150
Neither
I would go with B&M, and I did.
Good luck with it, Toby
Old 08-22-2002, 03:44 AM
Vehicle: 2005 Ford Mustang
Read this, it explains some of the shift kits for 4R100s.
G
http://powersurgeperformance.net/shift.htm
Old 08-22-2002, 11:26 AM
Vehicle: 2005 Ford F-150
i had the baumann kit. it was a nice kit and shifted well, but about a week later i had serious tranny problems. i believe the problems were unrelated to the kit. anyway, i got a new tranny from ford under warranty. i ordered a replacement valvebody and teep aluminum transmission pan from performance automatic to put into my new tranny. the valvebody they make is like the one factory tech makes, but it is for the 4r70w. i should have it today or early next week. i will let you all know how it works. thier website is www.performanceautomatic.com you may also want to try www.lentechautomatics.com they make good stuff for the 4r70w too but it is a bit more expensive. if you want more info on these companies check out www.corral.net there is alot of stang owners who use these parts.
-steve
2005 F-150 SuperCrew FX4
Appearance - Nifty Coverall Floormats * Line-X Bedliner * C.M.I. Low Pro Black Toolbox * Back Carriage Works upper and lower grills * Front window tint * Depo Black Headlighs * Black tinted tail lights and 3rd brake light * Black 20" Factory wheels * 33x13.50R20 Super Swamper Iroks * 2 1/2 inch Autospring * Skyjacker Add-a-leaf
Audio/Security - Python 881XP Alarm/Remote Start * Infinity Kappa 680.1cs Components
Performance - Edge Evolution
Gallery
Old 08-22-2002, 10:08 PM
Vehicle: 1997 Ford F-150
Baumann
I installed the baumann kit a year ago.
I have not had any problems AT ALL!!!
I love the way it shifts but I don't recommend stage 5.
Unless you wear a neck brace at all times... : )
97 F-150 Lariat 4.6L
4x4
Black/Silver
Mods so far:
TPS Mod,
Airaid intake,
Fowmaster "Y" pipe,
Flowmaster Exhaust,
SuperChip,
Flex a lite Elec.fan,
Modified MAF,
Underdrive pulleys,
Baumann Shift kit on 5,
B&M Trans pan,
Mechanical Water,oil & voltage Gauges on 3 pod piller,
Platinum +4's,
Accel 8 MM wires,
Accel Coil Packs,
Hellwig sway bars,
Poly bushings,
Edlebrock IAS shocks,
SS grilles,
Lightning Tails,
Clear corners,
Kenwood Audio system,
Old 08-22-2002, 10:47 PM
Vehicle: 2001 Ford F150
Send a message via AIM to GearHead_1
Transgo, definitely. I've put in over 20 of these and never had a problem with one.
Old 08-22-2002, 11:51 PM
Thanks for those links 2000F-150HD , I'll check them out tonight. Joe T what setting do you have your Baumann on? I wasn't considering putting it on stage 5, but does anyone know how the stage 3 setting on the Transgo is? I actually would like to have a little 1st to 2nd tire chirp and am curious which setting on the Transgo or Baumann would give me that chirp without having to put it on the max setting. My truck already kicks pretty hard into 2nd because of the Chip, but I still feel that the tranny needs to shift a little firmer. I should have shown my sig. earlier but I forgot, so here it is. By the way, I also plan on getting Sonnax vavles along with the shift kit.
Bright Red '99 F-150 xlt Reg.Cab flareside sport pkg. 5.4L 4x4,K&N FIPK, SuperChips Microtuner, custom tuned SuperChips flip chip, 3.55ls,Gibson Dual Sport exhaust, Gibson stainless steel headers, poweraid Throttle body spacer, ford racing 24# injectors, ASP Power Pullies, Flex-a-Lite Dual electric fans, and now I also have a.....
2003 Dark Shadow Grey Lightning- 6lb pulley, JLP Ram Air, Nitto Drag radials, and getting ready to buy a Diablo predator tuner.
Old 08-23-2002, 12:04 AM
Stage 2 with the TransGo kit will give you that 1st to 2nd chirp. With a Superchip that isn't calibrated to compensate for the shift kit, stage 2 will rock you.
Old 08-23-2002, 12:43 AM
stage 4b on the baumann gave me a lil chirp on the 1-2. but i have no chip. so i still have all the torque management and the low line pressure. but, i do have a supercharger as well. i think you would be happy at a level 4 on the baumann. i will let you know how the PA valvebody shifts when i get it in.
-steve
Gallery
Old 08-23-2002, 01:26 AM
Steve,
Could you be sure to take some good pictures and study the valve body thoroughly before installing it??? I'm curious to know exactly how it's put together.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
