F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-11-2002, 01:57 AM
Vehicle: 1997 Ford F150
Tranny Problems??
I have a 1997 F 150 with automatic transmission. Do not know the service history of the tranny as I just bought the truck. Anyway the big problem that I am having is that once the truck takes off for the first time and shifts for 1 to 2, it seems like that then it just stays in 2nd even when coming to complete stop and then it takes off in 2nd. It will not shift into any of the other gears. Could this be a torque convertor problem or just something as simple as a sensor of some king telling it when to shift?? Any help would be greatly appreciated.
Scott
Old 06-11-2002, 09:21 AM
Vehicle: 2000 Ford F150
How many miles on the tranny? Has the fluid ever been changed? How does the fluid look/smell?
May be as simple as a fluid/filter change.
2000 F-150 XLT Sport, Silver 4-door Supercab StyleSide
Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires, 3.55 Open, 4.6l V8,
Automatic Trans (First one in 20 years)
In-Dash Single CD Player, 60/40 Split bench - dark graphite
MODS SO FAR
Gatorback Spray-In Bedliner, Llumar ProShield Window Tint
WMS Velocity Tube (removed due to hum), Black Westin Step Bars, Lund Trident Hood Deflector (removed to paint), Fumoto Oil Drain Valve, FlowMaster Delta Flow 50 muffler in place of stock, DeeZee Silver Series Black Single Lid ToolBox; Extang Black Max tonneau cover; Factory Tech Valve Body & Accumulators; 5-channel amp w/ 8" RF sub in custom box and 5x7 Pioneer speakers;Superchip MicroTuner model 1715
Old 06-11-2002, 10:09 PM
Vehicle: 1998 Ford F150
Fluid change and probably something is buggered somewhere else in the tranny, probably not the torque converter as you're still moving forward. There are a few solenoids in there as well.
Check your shift linkage and make sure it is working properly. Sometimes I've heard it can be in a different gear at the column than compared to what it's telling the tranny and the computer gets confused or something.
Old 06-13-2002, 03:39 PM
I was driving down the rode today and it would not shift out of second again so I pulled up to a light and shut the engine off, started it back up and it shifted fine the rest of the time I was driving it. Weird huh? Could this be some sort of electrical or computer problem? Will an OBDII code reader read codes or problems with transmissions??
Scott
Old 06-15-2002, 06:43 PM
This problem is definetly got me stumped. If I turn off the engine and then start it again, after noticing that it won't shift out of second, the truck will run and shift normal everytime. What could cause the problem that shutting off the engine and turning it back on would solve??\
Scott
Old 06-15-2002, 07:27 PM
Vehicle: 2003 Ford F150
change out the fluid and filter(you may find that the old filter is not all the way up into it,s carrier),get out as much of the fluid as you can by draining the torgue convertor.put in a can of seafoam trans tune and give it about a week. mine had the same problem and it cleared it up. seems that the soliniod valves were sticking and the seafoam cleaned them up
Old 06-15-2002, 11:39 PM
Thanks TexFordD. I will try it and keep you posted. I hope this works.
Scott
Old 06-22-2002, 06:01 PM
Seafoam Trans Tune
Hey TexFordD,
Do you remember where you got the Seafoam Trans Tune that you were talking about. I have looked at the local Autozones and Advance Auto parts store and have not been able to find it. Any info would be appreciated.
Scott
Old 06-28-2002, 02:36 AM
Registered User
Vehicle: 2001 ford f150
Send a message via Yahoo to mlaugh
shift
Try this .....it cost nothing.
Disconnect the battery for like 20 minutes. Make sure your turn the lights on to drain any reserve power. Then reconnect and let it idle for 1-2 minutes. Then drive the $%it of out it. You know,.... full throttle starts and downshiflts etc. If you dont notice a change you better get that truck to the nearest Dealer.
Mike
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
