F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-10-2002, 11:45 AM
Vehicle: 1999 Ford F150
New Fluid, but Old Filter
I bought everything to change my transmission fluid and filter last week. I have the 4r70w. I got under there and started going to town. Took off the pan and filter. Let everything drain. I grabbed the box for the new filter and guess what, they gave me the wrong filter. I bet it's for the 4r100. I told the guy exactly what I needed. The new filter was way too long and there would be no way for it to work. So I put the old one back. It has about 30,000 miles on it. I finished the rest of the change, including the torque converter. So now my question is, how bad is it that I re-used the filter? I am thinking of pushing the auto store to give me new fluid when I take back the wrong filter. Suggestions?
Thanks everyone.
'99 F150 SC Lariat 4x4 Deep Wedgewood Blue w/Harvest Gold 2-Tone, Medium Prairie Tan Leather, most of the factory options, Modified Polar Bear Brush Guard, 2 165W KC Daylighters, Ford Factory Steb Bars, Extang Tonnuea Cover, Duracoat Liner with Rubber Mat, Flowmaster 50 series, Superchip, K&N Filter, Airbox Mod and Silencer Removed, 2 Rockford Fosgate 8"'s and a 250 watts RF amp,
Old 06-10-2002, 12:08 PM
Vehicle: 1997 Ford F-150
Ford's only recommendation for changing the transmission filter, is to do so if it's clogged.You don't need to change it. I wouldn't worry too much about it. You should probably change it next time though and never worry about it again. While you're at it, install a drain plug on the pan so it's a simple process next time.
Old 06-10-2002, 01:27 PM
Drain Plug
What is the best way to install a drain plug? Is there a particular brand of part to use? Can this be done at home, or does it require any welding/brazing? Is there a suggested place or position on pan? Thanks
Old 06-10-2002, 02:10 PM
B&M makes a drain plug. You drill a hole in the pan and screw it in. The best way to do this is to have a nut welded to the inside of the pan so that there is no risk of the bolt stripping, and slipping out. I can't think off-hand where to put it but I don't recall anything in the transmission hanging down far enough that it would interfere.
http://store.summitracing.com/global.../BMM-80250.jpg
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
