F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-07-2002, 04:18 PM
Vehicle: 2001 Ford F150
Transgo?
I just installed my trango shift kit, and set it up for the stage 2(middle drill bit) when Im driving normal it shifts hard 1-2 &2-3, is this normal? I dont mind it but I wanna make sure its not FUBARed.
"Happiness is being Blown"
2001 Supercrew 5.4
*Vortech V-1 Supercharger
*Dual 16" electric fans
*JDM chip
*Autometer water temp,oil pressure, Boost gauges
*Belltech 3/5 drop kit
*Air lift "Slam Air" rear airbags
*transgo shift kit
*Rear swaybar
*42lbs injectors
*Lightning Mass Air Meter
*Dual walbro 155lph fuel pumps
Next mods:
*intercooler
*Street sceens side skirts
*Snuglid
My BlownScrew
My Cobra
Old 06-08-2002, 07:07 PM
Vehicle: 1992 FORD F-150
Send a message via AIM to CHADSIX
ARE YOU RUNNING THE E-40D? IF SO THE TRANSGO SHIFT KIT IS YOUR BEST BET AND THATS WHY YOU DRILL THE SEPERATOR PLATE FOR FURMER SHIFTS AND BETTER FLUID TRAVEL BUT IF YOUR RUNNING THE AOD YOU MIGHT HAVE A PROBLEM NEVER USE THAT KIT FOR AN AOD TRANS HOPE I HELPED
Old 06-09-2002, 01:28 PM
Send a message via AIM to GearHead_1
Are you running a chip along with the shift kit? If so and it isn't set up to compensate for the Transgo, both it and the shift kit raise pressure and it will shift VERY hard. I've experienced this first hand on my SuperCrew.
Old 06-10-2002, 11:32 AM
Vehicle: 2000 Ford F150
Quote:
Why do you say we should not use the Transgo kit for my 4R70W?
2000 F-150 XLT Sport, Silver 4-door Supercab StyleSide
Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires, 3.55 Open, 4.6l V8,
Automatic Trans (First one in 20 years)
In-Dash Single CD Player, 60/40 Split bench - dark graphite
MODS SO FAR
Gatorback Spray-In Bedliner, Llumar ProShield Window Tint
WMS Velocity Tube (removed due to hum), Black Westin Step Bars, Lund Trident Hood Deflector (removed to paint), Fumoto Oil Drain Valve, FlowMaster Delta Flow 50 muffler in place of stock, DeeZee Silver Series Black Single Lid ToolBox; Extang Black Max tonneau cover; Factory Tech Valve Body & Accumulators; 5-channel amp w/ 8" RF sub in custom box and 5x7 Pioneer speakers;Superchip MicroTuner model 1715
Old 06-10-2002, 10:47 PM
Thumbs up
Put mine in a 4R70W. Works great!
Old 06-11-2002, 12:57 AM
Vehicle: 2004 Ford Excursion
Yep, that means you got it in and it's working. I went with 3 and ended up 3 plus some and yes, it can hit hard. But normal driving it's just nice a "crisp. You get a little pat on the rear end quite a bit as it shifts.
2004 EDDIE BAUER EXCURSION, White, 4x4, 6.0 PSD
Eddie Bauer Premier, Trailer Tow Group, Cargo Group, DVD w/wireless, 3:73 LS, TC Skid Plate
Magnaflow Exhaust, Isspro gauges, V Code's, 285/75/16 Bridgestone Dueler Revo's
Old 06-11-2002, 10:30 PM
Yea I figured. Im not complaining. I just a 456 rear in the cobra.....Talk about neck snappin! Thanks guys
Old 06-12-2002, 08:11 AM
Still like to know why CHADSIX says not to use the TransGo in an AOD tranny.
Old 06-12-2002, 11:04 AM
I don't have an answer for his comment but I don't believe that this is an informed response. I've put many shift kits in and this one works as well as any install.
Old 06-12-2002, 11:44 AM
I thought that would be your response.....
By the way, has your video returned yet?
Have you been able to log onto the other site this morning? I get error pages on the forum.
Old 06-12-2002, 12:22 PM
Yeah, got it back yesterday. I'm sorry to say that I didn't realize who I was speaking to. Sorry bout that, you obviously already know my views. I'll shut up.
Old 06-12-2002, 01:21 PM
Thanks again for the video loan!
I wasn't trying to discredit your input or anything like that! I am shocked by his input and would like to hear his thoughts.
Old 06-13-2002, 09:05 AM
Vehicle: 2000 Ford Expedition
I'm curious about all the differences in results after the Transgo install. I had the Superchip in before installing the E4OD TG kit. I thought Mike T. said the basic SC program is set up to accept the shift kit in level 1, but may require a tuning with any other levels. Mike, sorry if I've mis-spoken.
I also started on level 2 (.094-.082-.094) w/a Sonnax valve replacement. I have a pretty even shift across the board. Really sweet with the new synthetic ATF. Normal driving gives a quick, firm, comfortable shift. At WOT again, pretty even, and a little more kick. Nowhere near chirping tires, although w/ 22's and A4WD I don't expect to lay rubber. Anyway, I want to go back and punch out to around .110-.094-.110 to see if it stays as even. Do you think I will notice the change? I can't afford to keep opening this thing up! Also, If you need to go bigger (holes), is the plate even necessary?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
