F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-02-2002, 01:04 PM
Vehicle: 2005 Ford F150
mercon V change interval...
hey folks,
i was just looking through my owner's manual and discovered that the mercon V tranny fluid in my 4r70w tranny doesn't need changing for 150k miles.
is mercon V some sort of sythetic based fluid?
also, those of you who are "experts" at this sorta stuff...how long an interval would you go before changing out the fluid (since 150k seems like a long time)? especially if you don't regularly tow anything...thanks,
troy
2002 4x4 King Ranch S-Crew
Old 06-02-2002, 01:31 PM
Vehicle: 1999 Ford '02 F-150
I think that I have read that it is some sort of synthetic. I know the guys on the Lincoln Mark VIII site switch there tranny fluid to the Mercon V.
Old 06-02-2002, 10:38 PM
Vehicle: 2002 Ford E350
The factory fill MERCON V is a synthetic blend. You can buy aftermarket MERCON V that is dino, or blend, or full synthetic.
I would change the fluid in a 4R70W every 20,000 to 30,000 miles. It wears out.
Mark
Old 06-02-2002, 10:54 PM
Vehicle: 2000 Ford F-150 7700 4x4
Send a message via ICQ to Y2K 7700 4x4
I changed mine at around 12K 24K and 36K; and took apart the filters at the first and third change. Due to the lack of trapped particles (and the apparently excellent filter) I will likely revert to a method I've used for years:
Suck out as much as can be sucked out via a small tube jammed into the dipstic tube -- replacing with like amount -- once per year.
If I could find a reasonable synthetic -- I'd change it and forget it for several dozen K miles.
Y2K™ Jim
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Old 06-03-2002, 01:21 PM
Vehicle: 2002 Ford F-150
change it every 30,000 miles ......
Old 06-03-2002, 05:00 PM
Quote:
30k is what the special service section in my owner's manual recommends...but that is a huge difference between the regular 150k interval.
i figure since i don't tow anything on a regular basis...and live in a climate that is generally cool...i could prolly stretch that 30k out to maybe 50k...any comments?
Old 06-03-2002, 10:46 PM
You probably could stretch it to 50K, but I'll bet you will have torque converter shudder and will shorten your transmission's life.
Mark
Old 06-04-2002, 01:48 AM
Quote:
Mark
i thought ford specified the mercon v fluid to get rid of torque converter shudder in the 4r70w? when did ford start using the mercon v in the 4r70w anyway...is it relatively recent?
Old 06-04-2002, 09:23 AM
Ford switched to MERCON V in the 4R70W for the 1998 model year. The primary reason for developing MERCON V was to eliminate torque converter clutch shudder.
Mark
Old 06-04-2002, 11:57 PM
Vehicle: 1998 Ford F150
Switch at 30k miles. It's not that expensive and well worth the insurance policy you get by changing it. Trannies are expen$ive.
Old 06-05-2002, 08:26 PM
Vehicle: 2000 FORD F150
I thought that the recommended change interval was 15K not 150K. Anyways, I changed mine at 30K.
Jes
2000 F-150 Red, XLT, 4x4, 5.4L, 3.55, towing package (1.42" rad. Included)
Airaid FIPK, SI/DO Flowmaster 40's. Superchips FlipChip 87/91.
Stull Brushed billet grille with Ford Emblem. Radio Mod.
Home Brew Engine Compartment Ventilator.
Old 06-05-2002, 11:16 PM
Quote:
Jes
yeah, i thought the owner's manual on my '02 s-crew would specify every 30k too. but after looking through it, it doesn't recommend service on the 4r70w until 150k for regular use. all other trannies (ie...4r100, etc) it specifies 30k. the only reason i can see for this difference is the type of fluid used. apparently mercon v is a better more long lasting fluid as compared to plain old mercon. btw, the "severe service" interval is 30k for all trannies...at least according to my truck manual.
Old 06-10-2002, 01:35 PM
Mercon V
Where can I purchase the factory brand of Mercon V (synthetic) fluid? Do you know the code for the synthetic type, or is it packed in a particular color of plastic bottle?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
