F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-30-2002, 12:05 PM
Vehicle: 2000 Ford F150
Question leaking-pinion seal
I have a 2000 F150 4x4 (56k miles). I noticed oil leakage where the drive shaft goes into the transfer case (rear axle). I took it to the mechanic and he replaced the pinion seal. Everything is fine now, just wanted to know if anyone has had this problem and knows what could have caused this.
Old 05-31-2002, 11:47 PM
Vehicle: 2002 Ford F-150
mine had 8,000 miles on it when i noticed mine was leaking. took it to the dealer and they fixed it under warranty ofcourse. 17,000 miles now with no problems.... i wouldnt worry about it happens sometimes but shouldnt be a reocuring problem. 2000 f-150 4x4 xtra cab lariat 5.4l 3.55 ls
Old 06-01-2002, 02:51 AM
Location: Houston, by way of every major city in America.
Vehicle: 1998 Ford F-150
Send a message via AIM to 98SCREAMER
Thumbs up
Had mine replaced under extended warranty, no problem since,,,,98
1998 4.6 F-150 Super Cab. Over 136k and still going strong.
Old 06-10-2002, 11:41 AM
Vehicle: 1999 Ford F150
I have a similar problem with the leak. Mine has been doing it for a long time, but it has gotten alot worse recently. I always made sure the fluid is full. I wondered is adding the add-a-leaf made it worse because of the slight change in angle. Is this possible? Also, how much did could I expect to pay to have the pinion seal replaced?
Thanks in advance!
'99 F150 SC Lariat 4x4 Deep Wedgewood Blue w/Harvest Gold 2-Tone, Medium Prairie Tan Leather, most of the factory options, Modified Polar Bear Brush Guard, 2 165W KC Daylighters, Ford Factory Steb Bars, Extang Tonnuea Cover, Duracoat Liner with Rubber Mat, Flowmaster 50 series, Superchip, K&N Filter, Airbox Mod and Silencer Removed, 2 Rockford Fosgate 8"'s and a 250 watts RF amp,
Old 06-13-2002, 01:29 AM
Vehicle: 1998 Ford F150
Extended warranty took care of mine. Pinion seal failed at 41,000. I have a '98 XLT 4.6. Yeah it's plenty hot here in S.W. Houston.
Old 06-13-2002, 04:49 AM
How much does a Rear Pinion seal replacement cost?? Just looked under my truck and it looks like I have the same problem. I'm not very happy about it either. Guess I better make a appointment at the dealership!
PBALL
99 S/C ORP
Bright Red
5.4L Auto
Old 06-20-2002, 12:30 PM
Zyg Zyg is offline
Vehicle: 2002 Ford F150
Back in the day when I used to 4-wheel more often it would happen on occasion. Usually from one of 3 reasons. We would get a lot of grass/tall weeds wrapped around driveshaft and they would slide down and wear on seal. A plugged breather tube wouldnt cuase preasure buildup and blow seal, and the most common one was due to bad u-joints causing a sloppy sharft rotation which put a lot of extra wear and tear on the seal.
In my old blazer I replaced the rear transfer case seal 2x within a couple months before I realized it was bad u-joints, but because of the CV (srping and ball loaded) it kept constant preasure on the u-joints so it was impossible to tell they were worn without pulling the thing apart.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
