Just like to let all of you 5-speed's know that I'm in the works with short throw shifter. It will be a stock shifter that will be machined shorter and will come in 2 models... stock shift nob and threaded nob so you can use aftermarket shift nobs.
God... I hop I'm not violating vendor rules.
probably be available in 2-4 months. I've got alot of work still on getting up and running.
Just really wanted to know who is interested so I can see how many I need to make for my first batch.
__________________ '02 4.2 5-spd
Ported Throttle body
Mac Intake Fordchip Flip-chip in the mail
Superchip On the shelf
Straight Pipe
ASP Pulleys
Electic Fan
Centerforce Stage 1 Clutch
Powertrax Lock-Right Locker
Nitrous 75HP Kit
Hellwig Swaybar
Belltech 2" Shackles
SVT Lightning Leaf Springs & Coils
Clear Corners & Clear Tails
White Face Gauges
White Faced A/C
Acetone Emblems
15% Tint
How about some pics when you get one made up.
I was looking in my service manual on cd, at the shift lever removal. It seems that it would be possible to modify an aftermarket shifter to work. I think it would be necessary to weld the proper end to connect.
Anything would be better than what we have. If you can come up with something that would improve shifting, you would have at least a few sales here!
Idealily a short throw shifter assembly, one that changes the piviot to reduce the throw, would make the most concrete difference. Hurst (nor any other maker) has brought a device like this to the table, yet. Looking at the linkage it's clear that a short throw shifter for our trucks isn't quite as easy as one for say yhe Mustang.
__________________ Tom '07 Ford Edge
Ford says the Edge is a truck/SUV.
Yeah... I'll post another thread when I finally do get the prototype made.
I'll keep you guys posted.
Straight Pipe
ASP Pulleys
Electic Fan
Nitrous 75HP Kit
Hellwig Swaybar
White Face Gauges
White Faced A/C
Acetone Emblems
15% Tint
if you are able include a feature that makes it impossible to overshift and break the shift forks. basically that would involve calculating the optimal shifter position for each gear and having stops that do not allow the stick to be rammed farther that is necessary; this just puts alot of pressure on the forks, which in the trannies that i've seen taken apart (tremec3550 and getrag from a chevy truck) are aluminum.
having stops is a good idea because then it would be possible to ram the crap out of the shifts without worrying so much.
