F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-13-2002, 02:01 AM
Vehicle: 2000 Ford F150
Question Baumann Shift Settings
Ok, I'm not happy with my Baumann shift kit performance and I'm considering pulling the valve body to check things out. The shifts are "mushy", not the slide-bump and certainly not neck snapping. I've set it for level 4, but did option "B" for the 1-2 accumulator. What accumulator settings did those that used level 4 select? I'm thinking I need to go to option "C", but a little apprehensive about just leaving out a spring. I'm stock w/o a chip. Also, gas mileage has gone from 350 miles per tank to about 260!
A link that might be helpful, http://www.transonline.com, has a lot of info and good valve body pictures.
Any other thoughts for not getting the level 4 performance everyone else seems to be getting? Thanks. Mike
2000 F150 5.4L XLT
2WD Dk. Blue SuperCab FLARESIDE
Towing pkg
FREE real HD Ford radiator
Baumann Shift Kit
Hellwig frt. sway bar
Westin Nerf bars
Deflector bug catcher
Clear corners
DIY airbox and silencer mod
Linex bedliner
Berlin flip-style tonneau (love it!)
RS9000 shocks
Yoko Geolanders AT+II 265/70/16
Old 05-13-2002, 10:15 AM
Mike-
Did you use the "LONG" main pressure regulator spring? My BE is set like this: Level 4, long MPRS, other settings on "B/supercharger", and includes the OD mod. Without the Superchip, it's firm, but not neck snapping (it does lay 1-2 scratch at WOT every time). With the standard Superchip added, it's more my style. Shifts are progressively hard at all throttle positions and spins the tires on 1-2 WOT; 2-3 WOT hits like a rock. The key is combining the two products; the shift kit cannot eliminate the electronic engine management limitations that the Superchip can.
Old 05-13-2002, 10:35 AM
Thanks Max
Thanks for the info! I pretty much decided I needed to go back in and add the long pressure reg spring. Nice to know setting "B" is correct. Did you use the recommended number of spacers or something different? Thanks again.
Old 05-13-2002, 11:11 AM
Mike-
You're Welcome !! On the 1-2 accumulator, I used the 1996+shims, then B/superchager-2 springs and one spacer. As far as the main pressure regulator spring goes, I used the long spring and the Sonnax valve. The warnings in the instructions are a bit much IMO.
Old 05-14-2002, 10:37 AM
Question Another question Max
The 3-4, 4-3 modulator instructions refer to two different springs. One spring is for normal app and another for correcting a "flare" downshift condition. Which one did you go with?
I agree, the instructions are on the conservative side and in sore need of updating. My theory is that the older vehicles had very low torque, but when modified their torque became comparable to the newer vehicles. After all this, I think I'll set up a Baumann shift kit install shop! Mike
2000 F150 5.4L XLT
Towing pkg
Baumann Shift Kit
Westin Nerf bars
Clear corners
Linex bedliner
RS9000 shocks
Old 05-14-2002, 12:23 PM
Mike-
A "shop"= funny stuff . Really, they could update easily for everyone instead of letting everyone figure it out (Come on folks, can we say "word processor"). Anyway, the 3-4/4-3 upshift mentions 2 modifications. I installed 3 spacers in the 3-4 capacity modulator valve, since I used the long main pressure regulator spring. Next, I DID add the high-torque overdrive servo regulator spring. This spring simply replaces the factory one. I'm really pleased with my shifts when the Superchip is in; it's harsh the way I like it .
Old 05-14-2002, 12:47 PM
Thanks again Max!
Yeah, I thought about asking Greg to email the instructions in a file and I'd re-write them. For a fee! They need to pay some poor college kid $50 and get it updated.
You saved me another tear down as I would have NOT changed the OD servo spring. Jeeze! Let's make something simple complicated!!! Hey, at least I have nice clean trans fluid from all the re-dos...Thanks
Old 05-14-2002, 01:46 PM
Thumbs up Mike-
You're more than welcome; anytime !! Good luck, try to keep your hair out of the ATF .
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
