4R70W Fluid Capacity??? - F150online Forums
Old 05-01-2002, 11:04 PM
Question 4R70W Fluid Capacity???
I will be ordering Amsoil AT fluid soon for my 4R70W with the heavy duty trans cooler. I will be pulling the pan, draining the TC, and blowing out the cooler lines.
I've read that 13-14 quarts are required for a complete fluid change-out. However, with the larger factory cooler, would I need a tad more...say 15 quarts?
Thanks in advance!
Kevin
Old 05-02-2002, 09:20 AM
Maybe part of one quart for the cooler. Certainly not two additional quarts.
Mark
Old 05-02-2002, 10:41 PM
Mark,
Thanks for your reply. Guess I'll 15 quarts to be sure!
Old 05-06-2002, 11:27 AM
Make sure you fill the last few quarts slowly so you don't overfill it. Without flushing the cooler but draining the TC I put in 12 quarts I think because there was still a quart or so in the lines.
Old 05-06-2002, 10:59 PM
Thanks P!...I will take your advice.
Old 05-07-2002, 11:11 AM
Put about 6 quarts in, start it up for 30 seconds, fill another 2-3 quarts, run 30 seconds. Keep doing this till you get to 10-11 quarts. Then slowly fill it. Run it for a few minutes, check the level. If you overfill it's the most convenient to pull the TC plug and drain it slowly there instead of messing with the pan or insert a tube into the filler neck/dipstick and vacuum some out.
See my how-to here (4R70W):
http://members.shaw.ca/pferlow/transmission_oil.htm or
http://www.fordf150.net/howto/transmission.htm
Old 05-27-2002, 10:22 PM
No TQ drain bolt
After going through all th information here I could...I went and changed the fluid and filter in the tranny. Only problem is there was no drain bolt in the torque converter.
Any ideas on how to drain it without a drain plug?
'02 Screw 5.4, 4x4.
-Greg
Old 05-28-2002, 12:39 AM
Greg,
With the tranny in neutral (emergency brake on and the front slightly jacked up), did you slowing turn the engine with a 1/2" breaker bar on the crankshaft dampner nut while feeling, or looking for the drain plug on the torque converter? If so, and you could not find it, they must have redesigned the TC for 2002 and saved 22 cents!
I was able to use my right arm on the breaker bar to turn the engine over and used my left to feel for the plug...quickly found mine.
Kevin
Old 05-28-2002, 01:11 PM
TC is similar to superduty..
Tried looking for the bolt for a long time... breaker bar...starter...even ran the engine while lightly dragging a wood stiring stick across the TC through the inspection port (to feel for it as I might have missed it using the previous methid.)
There is definatly no drain bolt for my 2002.
After looking around and reading a link to the Superduty site...apparently there are others without the drain plug....
How to drain it: disconnect the lines rinning to the cooler and put them in a bucket. Idle the engine until some air comes out of the tube. Immediatly shut off the engine (this will get most of the fluid in the pan as well making it easier to remove). I guess this method is in the Ford service manual...
-Greg
Old 05-31-2002, 11:10 AM
Ford... for removing the drain bolt... YOU SUCK!
Old 05-31-2002, 04:18 PM
The drain plug was deleted starting in August, 2001.
You can still change all the fluid, but it's not quite as easy. Here is a link to a procedure for a 4R100, but all transmissions are similar for this:
http://www.ford-diesel.com/faq/1999f...ance-AutoT.htm
Mark
Related Topics
Thread
Forum
Replies
Last Post
buddyL
Transmissions
4
10-27-2016 09:48 AM
nickbrumaghim
11-14-2015 01:29 PM
2015f-150
10-04-2015 04:03 PM
Michael Roberts
V8 Engines
0
09-28-2015 09:46 AM
02xltscab
Transmissions
3
09-26-2015 04:56 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
