F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-14-2002, 02:18 PM
WLF WLF is offline
Vehicle: 1997 Ford F150
Question A question for 97 4R70w owners
I just changed my fluid AGAIN to try to cure some shudder I have been feeling. Unlike the 3-4 upshift shudder, mine seems to come in on the down shift when I go to part throttle at 35-45.
My question is this. I have for the last two trans fluid changes used the synthetic blends rated for both Mercron and Mercron v.
My trans calls for Mercron but I have read posts that it is ok to use these synthetic blends. Has anyone else with this year trans used the synthetics??
I hate to waste $40 worth of fluid but if it is going to make a difference in the shift problem then maybe I should switch it out for Mercron only fluid.
Black 1997 F-150 4x2 Supercab Flairside with HD tow package, Sunroof.
2002 Lightning headlights.
Steel Horse billet grill with Blade Runner (I just love chrome).
Prestiege air dam.
4.6L with Superchip, K&N Generation II modified to use with Supercharger, Accel Coil Pacs, Troyer fans, Troyer trans cooler, Cat back Exhaust with Flowmaster Super 40 2 1/2" in and Duel 2 1/2" out with 3 1/2 Stainless tips out the back.
S.E.C. Polished alloy wheels, Style 27 (17X8) with 265/70-17 Bridgestone Dueler A/T Revo’s tires. Hellwig 1 7/16 front and 1 1/8 rear bar. Eaton Limited slip, 4.10 Ford Racing gears, TrickFlow rear diff support girdle.
Pioneer head unit with Cerwin-Vega 5x7's all around and Rockford Fosgate Sub in custom box with 300 watt RMS amp "THUMP-THUMP".
http://www.f150online.com/galleries/....cfm?gnum=1496
Powerdyne Supercharger at 9lbs, 42LB injecters, 90MM MAF, Superchips 4 program chip.
JBA Jet coated headers
How fast am I you ask;
"Slower then John Force... Fast enough for me and exactly as fast as I can afford"
NOW 9 YEARS OLD AND STILL TURNING HEADS!!
Old 02-14-2002, 04:12 PM
Send a message via ICQ to jpkaiser
I have this transmission and year truck. I just used Mercon fluid for cost reasons. The transmission is shifting and working just fine with the Mercon. I have used synthetics in other vehicles with out problems as well. However, I don't know if it will help you get rid of the problem you are having.
1997 F150 Supercab 4x4 XLT 4.6L
WMS Velocity Tube/K&N Filter
Procomp ES3000 Shocks
Procomp 33X12.50 17" Tires
Old 02-14-2002, 07:18 PM
My 97 had the "shudder" bad a few yrs ago under warrenty. The factory service people had the dealer flush & fill with mercon V (after 6 months of other fixes). It's been fine the 25K since. Dealer said use only mercon V.
07 F-150 Lariat-scab
Old 02-14-2002, 11:02 PM
WLF WLF is offline
Well it has improved since the fluid change. There is no other problems with the trans (certainly not enough to have a rebuild). It is a funny shimmy and very hard to duplicate. My truck is WAY out of warrentee so I guess I will live with it for a while.
I read somewhere in one of these post about an additive to help with the trans. Anyone know what that is??
Prestiege air dam.
Old 02-14-2002, 11:34 PM
Vehicle: 1997 FORD F150
Friction Modifier.
Old 02-15-2002, 10:40 AM
AB AB is offline
Vehicle: 1997 Ford F-150
Hi,
I put Valvoline DuraBlend ATF fluid (MERCON & MERCON V rated) around a month ago (?) Already did 3000 miles...
I cannot tell that anything has changed since then. No problems what so ever..
I have around 96000 miles on the truck...
_______________________
'97 Ext Cab, 4.6L V8
Old 02-15-2002, 11:33 AM
I used the Mercon / Mercon 5 fluid when I did the TransGo Shift Kit and all seems fine. Take a lickin and keeps on tickin...
97 F150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Live Wires & Coil Packs, Underdrive Pulleys, Troyer Performance Dual 16" Electric Fan Kit, 3.55 LS, EGR Bug Deflector, Retrax Bed Cover, BedRug, XL Full Length Running Boards,EGR Fender Flares, Air Aid Kit, Gibson Single Out Cat Back, Superchips, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks,Expedition Center Console
Old 02-15-2002, 03:31 PM
Vehicle: 1999 Ford F150
Your tranny will be fine with a full synthetic that meets Mercon ratings. I'm using the Valvoline Durablend ATF that meets both with no problems, but it sounds like synthetic is the next idea to get rid of the shudder. Best of luck!
'99 F150 Supercab Flareside 4x4, 4.6l V8, Auto, 87,000 miles and running strong...
Sold! '97 F150 Supercab Flareside, 2WD, 4.6l V8, Sold at 162,255 miles on the odometer.
Old 02-15-2002, 06:34 PM
I had the same problem in my 97. Took it to the dealer and had them change the fluid with Mercon V. Did you change the filter and also drain the torque converter? After the full tranny service, mine shifts like a charm with no chatter.
Old 02-16-2002, 12:24 AM
WLF WLF is offline
Yea, I did the torque converter and changed the filter.
It's kind of hart to explain, it shifts crisp as ever. I have the super chip which makes it shift very nice. It seems to hand up on the down shift...
I'm wondering if there is some kind of servo or something the effects the down shift that needs attention.
Old 02-17-2002, 12:27 AM
Vehicle: 05 Ford F250
Send a message via ICQ to Jimmy Lee
Valvoline Durablend here too!! No problems whatsoever!!
JJ
"If you're not gonna use your head you might as well have two as*holes"
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
