F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-09-2002, 04:43 PM
Vehicle: 2009 F-150
Tranny shimmy (thanks)
I just want to thank you guys for helping me out with my problem.
It was driving me crazy, if the dealer would have told me that I wouldn't have been in that situation in the first place.From now on I am going to drain and clean it every 25,000 mile's.The only thing that I did not do was drop the pan and change the filter.Now that I no how to do it thanks to f150world,they explained that you must also drain the torque converter and replace the filter.This time they sucked it out and pumped some were about 13 qts. back in.Does anyone no why the fluid helps the vibration in the transmission when it shifts from 3 to 4th. gear.Is that a common problem,I still think the f-150 shifts sloppy and hope they take care o the problem in 2004.
Thank's
Again
2009-Lariat
White Sand Tricoat
Sony Navagation/Sunroof
4 Door Crew Cab
400 Watt Rockford Fosgate Amp
MTX-5000 Dual Eight's Sub.
Black Tinted Window's,
Super Chip
[HAVE FUN]
Old 02-09-2002, 10:00 PM
Vehicle: 2002 Ford E350
Re: Tranny shimmy (thanks)
Quote:
Yes, it is a common problem.
What happens is that the additives in the ATF wear out. Once they are gone the "slipperyness" of the fluid changes. Once this is different the computer that controls the transmission can't control it properly.
Mark
Old 02-10-2002, 11:10 PM
Vehicle: 2009 F-150
Thank's Mark,
Finally my truck is running right again,how often should I change the Tranny Oil and is there an upgrade I can use or an additive I can throw in.
Thank's Again
2009-Lariat
White Sand Tricoat
4 Door Crew Cab
Super Chip
[HAVE FUN]
Old 02-18-2002, 12:29 AM
I'd change it every 20-25,000 miles. I do not recommend any additives.
Mark
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
