F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-05-2002, 04:08 PM
Vehicle: 2001 Ford F-150
Question Need Manual Tranny maintenance how-to?
I have 18,000 mi. on my 5 speed and I'm fed-up. The damned thing is a little too jerky for me, and I hate the grinding from 1-2 and 2-3. I assume it would help things if I drained and re-filed with a better lube. I'd really appreciate a complete how-to so I know what to expect, as I haven't done this since I was 13. When is this service recommended anyway? Do I replace filter? How do I drain? What tranny fluid should I use? Thanks!!!
-AR
"Hurst Equipped"
2001 F-150 XLT 4x4
- 4.6L PI Romeo 5-Speed
Mods:
- SCT Xcal2 (Dyno Tuned)
- P&P TB & Elbow (Massaged Intake Manifold)
- WMS Velocity Tube (Ceramic Coated, K&N, Chopped Airbox)
- OBX Longtubes, Magnaflow Spun-Cats, Dynomax Race Bullet (Dumped)
- Ford Racing 4.10's w/ Cobra LSD
- Pro Comp X-A/T 305/65R17's
- Hurst Billet Plus Short-Throw (Prototype)
- T.P. Pulleys w/ Gatorback
- T.P. E-Fans
- Denso Iridium Plugs
- Hard Anodized Plug Threads
Old 02-05-2002, 07:31 PM
Send a message via ICQ to Matt90GT
Get a manual.
Pretty easy. There are 2 plugs -- Drain and fill. Remove the fill first! That way you know you can fill the tranny back up. Then remove the drain plug. Once it is done draining, replace the drain plug. You will need a pump to get the fluid into the tranny. Fill until it flows out of the top hole, about 3 quarts.
I run amsoil synthetic ATF and it works great for me.
Old 02-06-2002, 12:40 AM
Question Huh?
That's it? That's all their is to it? Cool!!! Should I notice any difference? So 3 qts. lubes the clutch and tranny, etc? Sorry, not too fimilar with transmissions obviously. I'm mainly concerned with the grinding...
-AR
Old 02-06-2002, 08:18 PM
Thumbs up Jackal-
That's it, very simple; no gasket, no filter. The fluid lubes the manual transmission not the clutch; the clutch is dry and separate. Happy Truckin' !!
Old 02-06-2002, 09:07 PM
Vehicle: 2000 Ford F250
I switched to Amsoil tranny fluid in my 5sp manual tranny..
I didn't notice any difference in shifting.. Still as clunky as when it was new.. However my tranny has never had any grinding at all, and it just turned 36k miles.
If your is grinding, then I would either suspect the clutch is not dis-enguaging all the way or you have a bad synchro in the tranny itself or your letting the clutch out too soon during the shift.
If I were you, I'd have the dealer have another look at it.. (grinding is not normal).
Y2K F250 XLT SC 4x2 5.4L 5sp 4.10LS
Old 02-06-2002, 11:10 PM
Thumbs up ...
Thanks guys!!!
-AR
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
