F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-05-2002, 03:21 PM
Vehicle: 2001 Ford F150
Trans squeals on shift
I have a 2001 SuperCrew with the 5.4 and (I’m pretty sure) the 4R70W. I have noticed that when I jump on it hard off the line, I get a rather disturbing squeal or squeak noise on the 1-2 shift, and now that I think about it, I may get the same thing on the 2-3 shift as well. Much as I’d like it to be, it damn sure isn’t the tires, so I’m about positive it’s the trans that’s making the noise. I rarely run the truck that hard, so it’s not as though the trans is abused. Any ideas as to what the problem could be would be appreciated, as I like to show up at the service drive armed with some knowledge as to the problem, to avoid service writer BS.
Also, this thing holds a gear like no truck I’ve ever had. Often times in 2nd or 3rd gear, even full throttle won’t give me a lower gear. Is this the standard for this trans, or is it a malfunction? If it’s a standard issue, then does anyone know of a mod that improves this without major surgery?
Thanks in advance for any help.
Old 02-05-2002, 05:07 PM
That squeaking noise might be the serp bellt slipping at high RPM's. Is the flat side of the belt glazed? Is the tensioner holding very tight? Just some things to look for.
Old 02-05-2002, 09:08 PM
Had the same thing happen to me. It was the serpentine belt. If under warranty they should replace belt and tensioner. All I did was replace the belt and it took care of it.
Old 02-06-2002, 05:46 AM
Start cheap! Check the belt. Mine did it just like you discribed.
99 SD, CC, 4x2, SHORT BED, V10(duh), 4R100 AT WITH TRICUMULATOR SPRINGS, 4.30LS, TOW & CAMPER PKG, XLT, OXFORD WHITE, PRAIRIE TAN, BORLA CAT BACK, BORLA HEADERS, K&N, EXTANG COVER (OFFICIALLY FOR SALE!)
Old 02-06-2002, 08:13 PM
Cool kliebeck-
1-2nd serp chirp is very common. It's most commonly the belt rubbing off all of the paint from the new pulleys and ruining the first one. Others have reported weak belt tensioners and loose/misaligned accessories.
Gears not kicking down????=not normal; mine kicks right down at every opportunity. Good Luck !!
Old 02-06-2002, 10:30 PM
I have the same problem with my SuperCrew; the first time it made a screeching sound I thought it was the transmission too - it was! Actually, I just installed the TransGo Performance Shift Kit in my 4R70W transmission. At W.O.T. it screeches very loud from 1-2, 2-3, 3-4 every time. I'm not sure a new belt and tensioner will do the trick. I tried two different belt dressing sprays, but that did not help. I try not to do the W.O.T. thing very often; mostly normal driving. One of these days I plan to up grade the pulleys and belt.
2001 F-150 SuperCrew 4x4
5.4L Triton V8
3.55 w/ Limited Slip
4R70W Transmission
Kenne Bell Supercharger - 10 PSI Boost
90mm Lightning MAF
Line-X Bedliner
Royal Purpule 5W-30
Hellwig Rear Anti-Sway Bar
TransGo! Performance Shift Kit AODE/4R70W
Magnaflow Cat-Back Exhaust P/N 15609
Rancho RS9000 Shocks
A.R.E. Z Series Cap
Denso IT-20 Plugs gapped .035
BBK 75mm Throttle Body
Walbro 190lph Fuel Pump
Firestone Firehawk 500 255/70SR16
Custom Tuned 6600 SuperChips by Mike Troyer
Old 02-12-2002, 03:59 PM
Vehicle: 98 Ford F150
Quote:
Wow, I feel better now. My truck has done this since I installed the Transgo kit. I set mine on "stage2". I called them up at one point and they said they had never heard of the sound before, though. It still worries me a bit.
How long have you had the kit in? I'm at 25,000 miles now, getting ready to change the oil again. Not looking forward to it.
Old 02-12-2002, 05:28 PM
Thanks for all the assistance.
Additionally, I'm looking into the Transgo kit to improve the TERRIBLE shift quality. I realize the kit will firm the shifts, but will it make the trans kick down more easily too? If not, what will? (I find the trans often holds gears when I want it to kick down)
Old 02-12-2002, 09:40 PM
My truck has the screeching belt on 1-2/2-3 shift at W.O.T. also, but the thing runs like a r@ped @pe! With my open differential though if I go W.O.T. it will smoke the drive tire through the first shift if it does not hit a patch of rough and then it will wheel hop a bit...
Old 02-13-2002, 01:35 PM
WLF WLF is offline
Vehicle: 1997 Ford F150
Kliebeck,
Superchip can fix the poor shifting problems without opening up the transmission. Just go to the superchip forum and send Mike a post.
My truck shifts better then ever and kicks down much faster. If you don't want to have to use super fuel then ask him to tune the chip for regular gas. I personally like the additional performance very much. Well worth a few cents more for super gas.
Black 1997 F-150 4x2 Supercab Flairside with HD tow package, Sunroof.
2002 Lightning headlights.
Steel Horse billet grill with Blade Runner (I just love chrome).
Prestiege air dam.
4.6L with Superchip, K&N Generation II modified to use with Supercharger, Accel Coil Pacs, Troyer fans, Troyer trans cooler, Cat back Exhaust with Flowmaster Super 40 2 1/2" in and Duel 2 1/2" out with 3 1/2 Stainless tips out the back.
S.E.C. Polished alloy wheels, Style 27 (17X8) with 265/70-17 Bridgestone Dueler A/T Revo’s tires. Hellwig 1 7/16 front and 1 1/8 rear bar. Eaton Limited slip, 4.10 Ford Racing gears, TrickFlow rear diff support girdle.
Pioneer head unit with Cerwin-Vega 5x7's all around and Rockford Fosgate Sub in custom box with 300 watt RMS amp "THUMP-THUMP".
http://www.f150online.com/galleries/....cfm?gnum=1496
Powerdyne Supercharger at 9lbs, 42LB injecters, 90MM MAF, Superchips 4 program chip.
JBA Jet coated headers
How fast am I you ask;
"Slower then John Force... Fast enough for me and exactly as fast as I can afford"
NOW 9 YEARS OLD AND STILL TURNING HEADS!!
Old 02-13-2002, 04:01 PM
I've had the belt squeal problem from day one. So far, they've replaced the belt, tensioner, and pully twice. Once before the install of the Superchip, and once after the chip had been in for about six months. The second time the service advisor at Truck City Ford in Buda told me it was sqealing because of the Superchip. He also gave me the act about the chip voiding my warranty, but that's another story. I'm beginning to think it's not the serpentine belt, but something in the transmission. Now, the transmission will slip out of gear if I'm going about 45-50 mph with my foot just barely on the gas. I think it's getting confused on the shift up into OD. When it does shift back into gear, it makes the exact same belt squealing sound as at WOT. Hmmmmm....... Oh well.......this is why I have an extended warranty.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
