HOW TO: Manual Transmission Ignition Lock Lever Removal
Doesn't that little lever annoy you because you have to push it in everytime you remove your key? Here's how to get rid of it so you can turn your truck off and take the key out without needing to press anything, just like an automatic truck. I opted for Option 2 so it will keep the lever and have a stock look, however when I get my nitrous kit i will remove the lever entirely and install my "ARM" switch in the small rectangular hole.
[list=1][*]Carefully pry the center trim panel off (dash cover behind steering column below gauge cluster)[*]Remove the ignition lock cylinder by inserting by turning key to "ON" position[*]Insert an 1/8" punch (or tiny screwdriver) into the hole at the bottom of the steering column cover push in a pin below the lock cylinder[*]Depress the punch while pulling the ignition cylinder out of the steering column housing[*]Use a small cresent wrench to remove the tilt wheel lever (if equipped)[*]Remove the 3 screws from the lower steering column cover[*]Seperate the cover halves and detach them from the steering column exposing lock lever[*]Option 1. Use a T-27 torx screwdriver and remove the ignition lock lever entirely leaving a hole in the cover[*]Option 2. Take a pair of wire snippers and snip off (ONLY) locking plastic part of the lever that locks ignition key from going to "OFF"[*]Re-assemble in backwards order[*]TOTAL TIME: 15 MINUTES[/list=1]
__________________ '02 4.2 5-spd
Ported Throttle body
Mac Intake Fordchip Flip-chip in the mail
Superchip On the shelf
Straight Pipe
ASP Pulleys
Electic Fan
Centerforce Stage 1 Clutch
Powertrax Lock-Right Locker
Nitrous 75HP Kit
Hellwig Swaybar
Belltech 2" Shackles
SVT Lightning Leaf Springs & Coils
Clear Corners & Clear Tails
White Face Gauges
White Faced A/C
Acetone Emblems
15% Tint
I had mine ripped apart because a metal arm binded and made key very difficult to turn. One minus 20 degree day the grease froze and it binded-turned it until it broke-DOH. Anyone else have this problem?? Mitchell on demand shows agood breakdown pic on steering column
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
