Which fluid aka TYPE do you recommend for my E4OD tranny in a 1995 E-350. and also what is the best internal replacement filter kit to use. would appreciate a quick response as i am trying to do this tomorrow i have heard mercron fluid etc and i didnt get a bok yet
You should check your owners manual or look at the dipstick. I think back then it was Mervon V.
The "dual rated" ATF that's not recomenned is Mercon/Mercon V compatable. You may find Mercon labeled and Mercon (Ford) Dextron III (GM).
Mobil 1 like Amsoil are universal and can be used in either application.
As for the filter, the one Ford uses is a Duetsch filter that you can either gte from Ford for close to $30 or go to an auto parts store like Autozone and get the exact same one for about $6-$8 less. I'm not sure anyone else makes one. The dealer even agreed that it's the exact same filter but that they can't usually compete with the auto parts stores on price.
__________________ 2004 EDDIE BAUER EXCURSION, White, 4x4, 6.0 PSD
Eddie Bauer Premier, Trailer Tow Group, Cargo Group, DVD w/wireless, 3:73 LS, TC Skid Plate Magnaflow Exhaust, Isspro gauges, V Code's, 285/75/16 Bridgestone Dueler Revo's
Mark, I stand corrected. I'm looking at a bottle of Mobil 1 ATF and it's say's "....meets DEXTRON-III and MERCON requirements."
It's also says in a bullet point "Mercon qualified by Ford for use in 1988 and later Fords or whaere Type CJ or H is required. Also qualified for all cars and trucks specifying Mercon."
Ok, so Amsoil is universal. I double checked a bottle of it too.
