F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-29-2002, 07:32 AM
AB AB is offline
Vehicle: 1997 Ford F-150
A piece of advice needed
Hi,
I changed the fluid recently (all 14 quarts) putting in Valovine DuraBlend ATF…
It looks like it improved mpg and added some power (maybe) and it sounds quieter (maybe)
But the pan and converter are sweating - there are no drops on the pavement and fluid level does not change but I can see some signs of the fluid on the pan and converter if I look under the truck. And the signs don't dry meaning that something is coming constantly out.
I understand that nothing is perfect… but let me ask this: do I need to worry about it, do I need to tighten the gasket a little or I can break it?
I changed the fluid on a dealer site – do I need to ask them to fix it?
All inputs will be greatly appreciated,
Alex.
Old 01-29-2002, 08:25 AM
Mine leaked for a little while after I changed the fluid because I had actually over-tightened the pan gasket. It stopped leaking when I loosened each of the pan gasket bolts a bit.
Did you check the torque converter drain plug and make sure that it's securely installed???
Also check and see if you can find exactly where the fluid is leaking from. See if it's coming from the transmission extention housing where the driveshaft is connected.
I'm a firm believer in the "you broke it, you fix it" mentality. Take it back if you can't see how to solve it yourself.
Old 01-29-2002, 10:01 PM
Cool AB-
It should be dry. That's too short of a time for seepage. Clean and monitor it until you see the leak location. Investigate and rule out spills. If someone else did it, take it back. Good Luck.
Old 01-29-2002, 11:01 PM
Vehicle: "99" FORD F-150
Cool
HI!... Mabey your torque converter drain plug was torqued improperly and is leaking. If that's what it is, when you drive your truck the wind passing under the truck then blows the tranny fluid to the rear of the truck. Check your T/C drain plug.
Old 01-30-2002, 08:44 PM
Send a message via ICQ to Bubbadewsky
Talking AB maybe your oil level is too high
I changed mine yesterday and drained as much oil out as is possible without tearing the tranny apart. It only needed 13 qt. to refill and I even drained the coolers and let everything sit for 24 hrs. Check your oil level with tranny at operating temp. 14 qts sounds like too much oil.
2000 F-150, XLT, SC, 5.4, 4X4, 355 LS, ORP, Black/Silver, class III, single CD, sliding glass, med. gray, keyless, elect. shift, engine date 8-18-99, Superchip. 2.02" corrected radiator-F75Z-8005-GA --- '93 Harley Fatboy Black & tons of chrome
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
