F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-27-2001, 02:52 AM
Lightbulb overdrive.
I have a 99 f-150, is therre any way to have the overdrive off when I start the truck and then turn it on when I want it? I don't like how it is the other way around. My trtanny guy says to keep it off below 60 to prolong life. If others drive my truck they don't always do as they're told. Josh
Old 10-27-2001, 03:01 AM
Vehicle: 1985 GMC Jimmy
O.D.
I don't know how to do that, but I don't think that you need to hold it out of overdrive unless it keeps shifting from 3 to 4 in town. It the shifting alot that causes the wear. Plus you will get better mileage if it will stay in overdrive. Chris
Old 11-01-2001, 03:51 PM
Vehicle: 2002 Ford F150
Got the same recomendation for in-town under 50. Don't know how to set the default to off though.
Old 11-01-2001, 06:05 PM
Vehicle: "99" FORD F-150
Cool
HI!... Turn the OVERDRIVE off and disconnect the wire connector harness up under the dash. I had a broken wire in the 3 wire, wire harness going up to the shift lever. For as long as the wire was broken the overdrive never worked. Just take the steering column covers off and trace back the 3 wire harness till it comes to the connector. Disconnect it and there you go. Hope this helps you out.
Old 11-09-2001, 11:10 AM
Vehicle: 2006 Ford F150
I'm pretty sure what he means here is: Is there a way to reverse the way the switch works? So that OD is OFF when you start up, and then when you want it, hit the switch, and turn it ON.
Old 11-09-2001, 01:50 PM
Vehicle: 1999 Ford F150
Doubt it, but.....
I am not a tranny expert, but I would have to say that there probably is, if you want to mess with the computer on the truck. Seeing that it is all controlled by the computer, or you could just use Neals' trick, that would work as well. Other than that, I would have to say that I doubt that there is a way to do that.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
