F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-16-2001, 07:35 PM
Vehicle: 1997 Ford F-150
Question Which speedo gear?
I did the math to figure out which vss gear I needed, but I'm not so sure its right. I'm guessing that I have a 19 t stock. I came up with 17.38. Is this right, and if it is should I round up or down? Seems like a drastic change for adding an inch or so of rubber.
My stock tires were 235/70/16 and my BFG's are 265/75/R16. My truck is a '97 F-150 4x4 4.6 R407W 3.55. Axle H9. It also has a nasty shudder @ 40mph. and shakes violently at stoplights.
Thanks, Jody
'97 F-150 4x4
4.6 Triton
R407W W/3:55 Ratio
265/75/R16 BFG AT's
FIPK
Straight Pipes
Rancho 5000's
2" Lift (Add-A-Leafs)
Old 10-16-2001, 08:58 PM
Vehicle: 1997 Ford F150
You are basically doing what I did. The only diff is I have the 5.4 and the 4r100 tranny. I do have the 3.55 gears and went from a 235/70/16 to a 265/75/16 tire.
My stock VSS gear was a 20 tooth. I replaced it with a 19 tooth. Before, I was losing 1/10 mile every two miles traveled. Now it's 1/10 every eight miles. About as close as I'm going to get, unless I get an even taller tire and switch to an 18 tooth gear.
I'd be only guessing, but I'd say you only need the 19 tooth one. Pull the stock one out first and count the teeth. Mine was black in color. The 19 tooth one was tan.
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
