F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-15-2001, 05:52 AM
Vehicle: 2003 Ford F-150
Better manual trans fluid?
I've got the manual trans in my 2001 F-150. It's got about 9,000 miles on it now. While the shifting is fine, I keep reading about problems encountered with this tranny. Is there a better fluid to run in the tranny that will make it shift better or last longer? I've heard good things about the Redline MTL (synthetic 75/80w). What does Ford recommend? I hope it's not the fish oil (80EP synthetic), that crap is $20 per quart from them. Has anybody changed to something that works?
Thanks,
Mitch
2003 F-150 XLT Sport 4.2L 5 speed YN Silver
275/45/R20 Yokohama Geolander HT-S on Boss 306 20x8.5 wheels
2003 Lightning leaf packs, Goundforce drop shackles
Chopped 03 Lightning coils, gives 1" drop in front
Troyer electric fans
troyer underdrive crank pulley
Airaid full intake
Custom ported/polished stock throttle body
Superchip
JBA headers
Straightened exhaust with Magnaflow 24" body muffler and real y pipe
Hurst short throw shifter
Lightning Bilsteins
Hellwig rear sway bar
Rhynolined bed
Snuglid Hard Tonneau
Keyless entry keypad mod
Alpine/Boston/JL /XM sat radio
Escort 8500 radar detector
2001 L grille inserts
Piaa air dam
Piaa Pro 80 XT fog lights
Piaa 510 driving lights
HD headlights and corners
Lightning 3rd brake light
http://www.superford.org/registry/vehicles/index.php?vID=3018
Next up:
What's left that won't void my extended warranty?
My old 2001:
www.superford.org/registry/?vID=14
87 Ford Bronco (Offroad Toy)
www.superford.org/registry/?vID=13
81 E-150 Van
70 VW beetle - POS but fun - Recovered from being stolen!
Old 10-15-2001, 10:59 AM
Vehicle: 2001 Ford F150
hello bronco . . glad your 5 speed is doing fine . . my 5 speed is doing well also . .
there are quite a few posts in the board about people changing to amsoil. some feel that their shifting improved. you might want to do a search or check archives.
Old 10-15-2001, 11:54 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Mitch,
If you do switch make sure you use ATF fluid.
Any good brand ATF synthetic will do just fine.
I went with the cheapest I could find locally. It happened to be Amsoil. Redline was a close second. Changing the oil will not harm your tranny but no one can guarantee that it will last longer.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 10-15-2001, 12:34 PM
Send a message via ICQ to Matt90GT
The transmission requires Mercon ATF, Mercon5 is usually recommended.
I personally use Amsoil ATF. I highly recommend it!
http://www.amsoil.com
Old 10-15-2001, 02:15 PM
Vehicle: 2001 Ford F-150
i used redline D4 ATF, its an atf specifically made for manuals. it improved my shifting quite a bit, but it was $8 a quart (only 4 qts needed though). its mercon, so it wont void the warranty...
2001 F-150 XL Reg Cab, SWB
4.2L, 5-spd, 3.55 4x1
Old 10-15-2001, 05:22 PM
Vehicle: 1999 Ford F150
Send a message via ICQ to bambino
The above mentioned brands were tough to find here in Edm, so I went with 3.75qts of Mobil 1 Synth ATF.
hth
Bambino
Come see our trucks!
Bambino's Photo Gallery
1999 reg cab/short box/ORP/Silver on Dk Graphite - 3.55; 4.6l 5sp; Factory Tonneau; Clear Corners; 40 chan CB/Maxrad Antenna; Kicker amp'd sub tubes; Rockford Fosgate components up front; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820s; Amsoil in the Diffs, Mobil 1 ATF in tranny and t-case, Ford Electrochromatic Temp/Compass Mirror
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
