Will Not Shift-1998
Will Not Shift-1998
I need help I have a 98 f150 trans went out so I went to junk yard found a 2000 with good tranny same as mine put it in now I only have drive no matter which gear I put it in I was told only the 98 would interchange after I put it in of course ,so my question is is can I change wiring somehow to make it shift right?
I know that I should not, but I made an assumption from where he said he got a good transmission the same as his out of a 2000. If that's truly the case then they would have to be.
But, also if that is truly the case then it would work. Unless there is another problem.
D
D
Yes, like I said, I made an assumption based on his words of same as his. He didn't say a truck the same as his, he said a transmission the same as his.
I would hope that anyone could tell the difference between those 2 transmissions if they were doing the swap themselves. They don't look alike and they certainly don't weigh the same. If not then they are likely beyond any help we could offer them.
D
D
