Reinstalling The Rear Differential Cross Pin
I removed the right rear axle on my 2001 F150 in order to replace a leaking seal. I have since replaced the bearings & seal. I am now trying to reinstall the axle but it will not go back in. I crawled under the vehicle and saw that the holes on the top/bottom spider gears and assembly are not aligned and I cannot get reinsert the cross pin back into place.
If I remove the left axle and rotate the drive shaft will the holes re-align or do I need to do something else? Can someone please help me?
Novice Al
Novice Al
