4R75W Slipping in forward
All at once the other morning transmission starting slipping bad. Had it towed home pulled the pan filter was laying in pan. Trans fluid is not burnt and pan is spotless which is surprising as there is 238k on it. I put new filter on replaced pan and filled with fluid but still slipping. Code that comes up is p0720 output shaft sensor. Could this be the cause? I would think if clutches where burnt than fluid should be burnt but its not still clean as I have it changed pretty regular. This is in a 2006 f-150
Sounds about right.
You definitely won't break the Sonnax drum. They are a strong replacement. Also a direct replacement. You do have to press your input shaft out of your old drum and into the Sonnax drum though.
Worth it is up to you. I don't typically use them unless specifically requested.
D
D
Well I just splurged and ordered the sonnax one. The truck has quite a few miles on it but its been a good one and no plans of getting rid of it yet.
Also ordered the sonnax shift correction kit to go with it. While I haven't had any of the shifting issues thought I would go ahead and put it in.
Got them from Oregon Performance.
