OD light flashing on install
So I Replaced 4R70W 2L1P-FA with a USED 1L3P-JA. So everything hooked up ok and the tranny works great. Problem is, is that the OD light flashes ALL of the time. No hesitation between blinks. Any ideas what the problem could be other than we may have bought a used wore out transmission?
This is on a 2003 F-150 4X4.
Cheers and Thanks,
Len
Cheers and Thanks,
Len
Here's what my Haynes says about a flashing OD light
"if the TCIL (the light in the shifter) flashes there's either a sensor failure or a short in the electronic pressure control circuit (EPC)
The book claims this is a dealer service item, may or may not be true. But they offer a way to check if it's just a bad switch:
a)Check fuse 29 (in your truck it should be 5A
b) remove the switch from the shifter and check the resistance. When the button is held down it should read less than 5 ohms when it's released it should be more than 10,000 ohms.
If it doesn't give you those readings it needs replacing.
if it does match those readings this is the next test:
apply 12v dc to the switch and verify the light comes on, if it doesn't replace the switch
Hope this helps.
Gene
Hope this helps.
Gene
Hope this helps.
Gene
Hope this helps.
Gene
As I said even though the Haynes manual says past those tests you have to go to a dealer, if you use the search feature you might find another answer or a person who has more transmission knowledge might offer more help yet tonight or tomorrow.
If the OD light is flashing, it's setting a OBD2 code that can be read by a high end scanner. Find someone with a scanner that can read Ford transmission codes and get them read. You don't have to go to a dealer but the readers at Autozone can't read them.
My Brother in law has a shop and can read the codes. I'll bring it to him and see what the codes are. Thanks!!
Those are some of the reasons the TCIL (Transmission Control Indicator Light) would flash. If there is a short of open in any wire to the transmission it will flash. If there is an internal problem in the trans and the shifts take too long it will flash.
The ONLY way to know what's wrong is to read the codes, as was stated above.
And that's why buying a Haynes (or Chilton's) manual is a complete waste of money. It's only good for tearing out pages to line a bird cage.
Fair enough, I grew up when those things were like hens teeth and a Chilton and later Haynes book was the best cost effective source for repair info for me.
I don't take everything as gospel in them, as I stated above, although my book said you had to go to a dealer for the OP's transmission issue after you performed their offered tests I wasn't certain that was a fact, and I said so. You verified that with your post
I just did a search on ebay for my personal truck manual, $120 is about $95 more than my Haynes. Certainly a good investment, if I were not planning to upgrade vehicles in the near future I would, I will invest after my next purchase.
Printed paper factory shop manuals still cost a small fortune - you do have to check the DVD listings carefully to make sure they are genuine.
This one is genuine:
http://www.ebay.com/itm/like/370897935328?lpid=82&chn=ps&ul_noapp=true
Note:
****These DVD's are date sensitive, so to get this to work on your PC, you must change your PC Date, to month/year DVD was produced. Due to age of DVD - will not work on Windows 7 / 8 / or Vista!!
Here is a non-genuine freebie, it can be hard to find what you need but everything you need *should* be there:
https://drive.google.com/file/d/0B52...hvNUYyaXc/view
Note:
I had a '92 Ranger. It came with a Chilton's manual. I had to change the clutch, so I opened the Chilton's to go over the steps to remove the transmission. All it said was to remove the transmission. It had NO further detail. I'm glad I didn't pay for that level of help. Maybe that would help someone with less experience than I have, but I can't see how it would help anyone.
