92 f150 wont shift after tranny flush
Old 08-15-2016, 10:09 PM
jakek88's Avatar
I had a transmission flush done on my 92 f150 auto. 220k miles. It worked but shifted hard before I had it done, now it won't shift past 3rd gear. Any thoughts? It's the e4od trans, and the fluid used was farmoyl brand ATF fluid. No lift kit, has 235-75-15 tires and its 4x4
Old 08-15-2016, 10:21 PM
glc is offline
Was the fluid Mercon or Mercon V? If not, you used the wrong fluid.
Old 08-16-2016, 07:12 AM
jakek88's Avatar
No, it was framoyl brand automatic transmission fluid, how do I know if I should use mercon or mercon v ?
Old 08-16-2016, 07:58 AM
Darrin Burch's Avatar
I'm thinking coincidence.
D
Old 08-16-2016, 10:16 AM
Mark Kovalsky's Avatar
You should use MERCON V. MERCON has been discontinued.
The first step to determine what's wrong is to get the codes read. Without codes it's all a bunch of guesswork.
Old 08-16-2016, 08:46 PM
glc is offline
The question is - what spec does that Farmoyl fluid meet? If it meets Mercon or Mercon V spec, it should be okay.
Old 08-17-2016, 10:46 AM
Is this the fluid you used? http://www.farmoyl.com/products/tran...ssion-fluid-dm
If so, I don't think it's the best choice, but I don't think it would cause any harm and it didn't cause your problem. This link says it is for use where MERCON was specified, but not to use it in MERCON V applications.
Old 08-19-2016, 06:18 PM
jakek88's Avatar
Yes it is.
Old 08-20-2016, 12:47 PM
My thought is that the transmission was about to die from whatever was damaged inside. Flushing the fluid didn't fix the broken parts inside and it died. I think it's rebuild it or replace it time.
Quick Reply: 92 f150 wont shift after tranny flush
