Replacing Tranmission Cooler Lines (04 SCREW)
Stuck with a bit of a problem - how do you remove the lines that go from the transmission to the radiator/oil cooler? I have a leak and I'd like to replace the line but can't figure out how on earth to remove the lines. I can get the lines out of the radiator using the Lisle tool and I can disconnect the lines from the side of the transmission, but there must be a secret to jockeying these 6 foot lines out from under the truck!
Thanks!
Thanks!
