2006 F-150 XLT 4wd 4R75E rebuild
Old 08-20-2015, 10:18 PM
mitymerc's Avatar
Arrow 2006 F-150 XLT 4wd 4R75E rebuild
Owner of this truck complained the transmission lost overdrive. I towed the truck to my shop. This truck has 309000 miles in the odometer, the transmission fluid and Transfer case fluid were black. The yellow dipstick plug was present when I pulled the pan. The magnet in pan has moderate metal contamination.
Everything in the transmission is coated with a black film. Originally, I expected to find the OD servo snap ring broken and debris from the snap ring lodged in the valves in the valve body, this wasn't the case. Once I got the transmission removed from the truck and taken apart, I found the internal splines on the direct clutch hub snout were stripped. This means this transmission had no 3rd gear or 4th gear. I have heard of high horsepower cars either stripping the splines on this drum or breaking the stub shaft, but I have never seen a stock vehicle do this.
The forward clutch material was dark and starting to pit, the OD band was glazed and the reverse band was worn.
For the rebuild, the direct drum was replaced, the OD band is updated to latest black high carbon material and because this is a truck, the reverse clutch is updated from 3 clutches to 4
Old 08-28-2015, 01:39 PM
Clayton Hayes's Avatar
309k, first rebuild?
Old 08-31-2015, 09:08 PM
mitymerc's Avatar
as far as I know... yes.
Quick Reply: 2006 F-150 XLT 4wd 4R75E rebuild
