95 F150 5.0 Wont Downshift
Old 05-29-2015, 03:51 PM
gibbonsballer10's Avatar
Truck wont downshift when you give it gas. Shifts gears fine but wont down shift. Will shift down into 2nd if you put the shifter into 2, but not when you press on the gas. Just replaced the tps sensor also.
Old 05-29-2015, 03:55 PM
Just one thread per subject allowed, so had to remove the other thread. Just causes too much confusion for those trying to help. If you don't get responses here, PM me and I can move the thread.
Old 05-29-2015, 04:37 PM
glc is offline
4R70W or E4OD?
Old 05-31-2015, 01:35 AM
Originally Posted by glc
4r70w or e4od?
4r70w
Old 05-31-2015, 02:26 AM
glc is offline
Any EEC trouble codes?
Old 06-01-2015, 05:16 PM
It's showing codes 122 and 565
Old 06-01-2015, 05:17 PM
Also it's like there's no power until it reaches 2000rpm. Very, very slow acceleration until 2000 rpms. This just started recently
Old 06-01-2015, 07:54 PM
glc is offline
122
Throttle Position Sensor Circuit Below Minimum Voltage
565
Canister Purge Circuit Failure KOEO
Your new TPS is defective, incorrect part, misadjusted (if it's adjustable), or you have a wiring issue.
http://www.enduringautomotive.com/tps/
You also have an evap issue but that won't cause your problem.
Quick Reply: 95 F150 5.0 Wont Downshift
