4r70w to aod
Old 05-12-2015, 08:22 PM
1985f1504x4's Avatar
4r70w to aod
I have an 01 f150 that is a work truck that the tranny went out on I need it running for little cost I have an aod sitting around will this swap work
Old 05-12-2015, 09:27 PM
Mark Kovalsky's Avatar
No. It won't bolt to the engine.
Old 05-12-2015, 09:55 PM
what about with a bellhousing adapter PLATE
Old 05-12-2015, 10:35 PM
glc is offline
It will bolt to the engine if it's a 4.2, but you won't have a speedometer, odometer, it won't run right, and you may also have driveshaft issues. It won't even shift right without a TV cable.
Old 05-13-2015, 08:48 AM
Darrin Burch's Avatar
That would be about the most expensive route. Getting an inexpensive stock rebuild from someone who knows how to do it or taking your chances with a used transmission that comes from a quality yard offering a warranty would be the least expensive.
D
Old 05-13-2015, 10:23 PM
With the right plate you can adapt any transmission you want. The problem is getting a custom plate made that WORKS probably costs more than the right transmission would cost.
Quick Reply: 4r70w to aod
