Lost Reverse
Lost Reverse
New here,be gentle. Anyway, I have been looking all over the net about this and found a lot of info and I'm sure the answer is in here somewhere. First, I have a 2007 F-150 supercrew 4x4, 5.4, lifted etc. Auto transmission. Was backing up a trailer the other day and, clank, no reverse. It drives fine,all forward gears work fine. So, what I understand is there is a band for reverse, when you put it in reverse something pushes down on it and away you go (simplified). So,my question is how much should I expect to shell out for this repair ? Going to talk to a transmission guy today. I live in California.
Broken snap ring on the rev. piston. I believe this is the fix from what I have seen here.
http://www.transgo.com/products.php?...3&prod_start=0
either the low/reverse band is broken ..
https://www.f150online.com/forums/tr...times-two.html
OR the sunshell gear is broken...
Well I'm no expert, but what I did was ask around about a good transmission guy. When I say a good transmission guy, I mean fair and honest and does good work. A friend has had this guy rebuild 3 tranny's for him and done a great job. All I can say is ask around. Good luck.
