M5R2 hard to shift
M5R2 hard to shift
Hi all new member here. I'll try and be as complete as possible but this kinda baffles me. Well about 4 months ago I was driving along and my transmission went. Had it towed back home and turns out input shaft bearing had completely fallen a part. Well I went ahead and rebuilt the trans took my time and double checked each step. Well I finally get it all together and today started her up.
At first o couldn't shift into any gear with engine running. Bled the slave cylinder a little more and now it can shift up though its a little hard. But I absolutely can not down shift at any time. I even heard grinding gears trying to go from 4 to 3. My question is did I miss something? It works OK when upshifting like new. Bit it just will not downshift no matter what. I even tried floating it in clutch less and it just wouldn't go. Anybody have any ideas?
on
Engine running 2000 rpm, try shifting from 1st to reverse and back again. If it grinds suspect the clutch. That is assuming you rebuilt the M5OD correctly. Which parts did you change? Did you follow the procedure for shimming the input and intermediate shafts? You took it all apart and cleaned every thing?
