Transmission Fluid Flush and Change
Greetings.
I am about to change out my 2008 4x4 F-150 4.6L transmission fluid and filter. I have 127K on the truck, mostly highway. Any recommendatiions on the filter and fluid? It has never been drained, changed or added too. Also I am hearing horror stories about changing the fluids with so many miles on the transmission. Any truth to it being better to leave the fluids as they are? Thanks
Luke
Luke
Greetings.
Luke
Luke
Filter: Motorcraft, from dealer, Rockauto, etc.
Change the fluid - all of it, using one of several methods (DIY or a shop using an exchange machine). No chemicals. Drop the pan, clean the magnet.
Whatever you heard is hogwash - change the fluid - regularly - yer already way overdue. If it fails soon after it will be from neglect, not the fluid change.
If Darrin or Mark chime in listen to them - they are the Experts. I'd certainly defer to them.
good luck
MGD
OP - drop the pan, clean it and the magnet - and replace that filter. It's fine enough.
Refer to: https://www.f150online.com/forums/20...ml#post5054038
MGD
MGD
I guess I learned something today. Back in the day when the Ford transmissions used "type F" transmission fluid, there was always a nice coating of black crud in the bottom of the pan along with some brass colored fine filings. I would hate to use an exchange machine without dropping the pan first on one of those that hadn't had the fluid changed in say over 50,000 miles. I would think the detergent in the new fluid would tend to wash up that black crud and circulate it through the transmission.
Just to clarify these were transmissions that worked fine both before and after the fluid change. I drained the torque converter also of course.
